Another Trunk not Opening
Old 01-07-2015, 09:06 AM
lupo7791's Avatar
2001 clk320
I was able to get to the trunk using the removing of the tray on the rear shelf. I was hoping that the emergency escape would be working but it's not.
Anybody has any suggestions as far as what to use on the mechanical key for the trunk, I have been soaking it with wd40 for a day now but it's still not turning counter clock wise.
Thanks in advance
Old 01-07-2015, 12:29 PM
CJackson13's Avatar
W208 CLK55
Go back in the trunk and unscrew the latch from the inside. The bolts are hidden underneath a small plastic cover.
Old 01-07-2015, 02:12 PM
lupo7791's Avatar
2001 clk320
Ok, I'll give it a try. Thanks!
Old 01-07-2015, 03:46 PM
CJackson13's Avatar
W208 CLK55
once the latch is free the trunk will lift up freely. you can disengage the latch and re-attach it to its original home. the whole system should work normally after that, at least it did for me. good luck!
Old 01-13-2015, 11:12 AM
lupo7791's Avatar
2001 clk320
Thanks Jackson, it worked just as you described.
Still not sure what happened, but there was some rust that I clean out and just as a precaution I added some white lube. It's been working ok since Saturday.
Thanks again, it's such a pain in the B@lls not having access to the trunk.
Quick Reply: Another Trunk not Opening
