cabriotop first didn't close , now doen't do nothing nomore
clk cabrio w208
hello,
my problem is last month after a death battery that i have replaced, i opened the top and this worked just fine but after a few hours i wanted to close it and the closing process stopped at the point when the deck normally closes, it just wouldn't come down anymore.
so i closed it manually like in the car manual discriped.
know today i thought i gonna try to open the top.
the windows are opening and then nothing happens nomore.
the button for opening/closing the roof blinks/flashes.
the flashes are blinking with about a second between each other.
the rollbar/headrests are working. i can turn them up and down with the switch.
clk cabrio w208
the softtop is open now
but there are some problems
after holding up the switch for the rollbar for 20 sec i hear a click.
then i turned off the ignition key and back on , i lowered the rollbar with the switch.
i noticed if the rollbar is down the topdeck that covers the softtop is moving to a little and this each time i do the rollbar up or down.
so what i do :
i release the top , pulled up the operatingswitch and at first nothing happened.
i opened the trunk released the softtop with that special tool that's inside the car (sixbolt )the part where the rearglass is in the top released. then i pulled back again the switch and the rear of the softtop opens.
the i noticed instead that the coverdeck opens , it wanted to close harder
so i used again that special tool and release the lock from the topcover (bowlock?)
then i pulled the switch again and it opened and the softtop did go inside the trunk then if the softtop was past halfway it stopped and i needed to helped it with the hand to get it fully in the trunk.
i had to close the coverdeck also manually because it didn't do nothing if i controlled the switch.
after closing the topcover i also needed to close the lock manually.
i noticed also everytime i turned the ignitionkey from off to on , there was a sound that's coming out the drivers door or after the passenger side panel.
so i think it might be a small problem but i don't know
so what i do :
