Suction Cooling Fan not running
Old 08-08-2015, 08:03 PM
bennernz's Avatar
W108 1972 280SE 4.5, R129 1994 SL320, W208 2000 CLK320 Cabriolet
Exclamation Suction Cooling Fan not running
Hi There
2000 CLK320 W208 - Behind the radiator Fan will not run.
I was hoping some one may have a Diagram of this function.
Have proved the actual Fan Motor is Good
Have replaced the Climate control unit - ( Cabin dashboard had to be done for another Fault)
Engine temperature display is working just fine.
I suspect the Fan Control/relay Part Number A0255455932 but would like to be able to test.
My car just has the single suction type fan not the additional s in front of the radiator
Has anyone else had a similar issue ?
Many Thanks
Quick Reply: Suction Cooling Fan not running
