CLK430 hesitation during rollng start
Old 08-27-2015, 12:07 AM
miatawnt2b's Avatar
2002 CLK430
I am having a strange hesitation issue and hoping someone can help.
If I am stopping for a red light, coasting to the light, car around 10mph or so light turns green. I ease on the gas to pick up speed, and there is 0 throttle response for about a second. Then it takes off.
I have no hesitation issues from a stop, or from speeds above 10mph, WOT is no problem.
Computer has no codes.
Thoughts?
-J
Old 08-27-2015, 11:16 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Could be pedal position sensor or sprint booster going bad if you have one installed here is a thread from benzworld
http://www.benzworld.org/forums/w208...m-strange.html
Hope this helps
Old 08-28-2015, 07:36 AM
Serndipity's Avatar
2001 CLK320 Cabrio
FWIW....while I was covered by the 5 year/50,000 mile MB warranty and scheduled services, I occasionally had the 1 second 0 throttle response when starting after a stop. Dealer asked if I ever braked with my left foot, which I occasionally did, would momentarily confuse the ECU. Nothing done.
Right after the 5 year term expired, with less than 50,000 miles, got a CEL which was due to a MAF fault code. Replaced the MAF, which is an extremely easy DIY and the issue went away.
Old 09-17-2015, 10:00 AM
jonUF02's Avatar
2015 GL550 4matic
This scenario might just be normal reaction time for the trans to kick-down properly. It can be pretty sluggish. This is why I always wanted to try the Sprintbooster.
Old 09-17-2015, 02:08 PM
miatawnt2b's Avatar
2002 CLK430
I thought I posted the fix, but I must have forgotten. I bought a new MAF and installed it. Hesitation completely gone and the car is much less sluggish in general. I didn't even realize it was sluggish until I replaced the MAF. It's like a different car.
-J
Old 09-18-2015, 08:25 PM
cindyclk's Avatar
Hope this helps
Pedal position sensor is usually the problem....MAF issues are quite common but usually there is hesitation and poor performance across the range.
Quick Reply: CLK430 hesitation during rollng start
