Are all Spring Compressors the same? Help needed...
2000 Clk430
Hello. I have a 2000 clk 430 and need to replace springs. The following two links show two different compressors.
http://www.ebay.com/itm/261721730544?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/262207959002?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The cheaper of the two does not mention the 208 being comptaible, HOWEVER, the more expensive of the two shows that it works with my model and the ones that the cheaper one works with. The plate size and "telescopic" length are the same, but i notice in the photos that the cheaper one looks slightly longer. Check the long rod on the more expensive one and notice how there is space when sitting in the case to the right of it. So, are these compressors all universal or can I only use the more expensive one? Thank you!
The space you refer to is just because one is compressed more than the other thats all. They have the exact same Telescopic range of 120mm-325mm and the plate sizes are also exactly the same.
The max load on the black one states Max Load:36 500 N. This is the only thing not mentioned on the cheaper one. I'd contact the seller and ask them and if its the same it may be worth saving the money.
I've owned the more expensive black one and it is solid as a rock, I highly recommend it.
I have had the springs in and out a few times on my '01 and never needed a spring compressor. I have always been able to drop the lower a arm out of the way and spring is unloaded in the process.
I agree that the spring compressor would make it easier and safer but I would say it's not a REQUIREMENT if you have done work with springs before.
The rear shocks and springs are a breeze.
KRis
