2002 CLK 55 AUX won't work
Old 02-09-2016, 11:20 PM
Jake Hoiseth's Avatar
CLK 55 AMG
I recently got a 2002 CLK 55 this November, and it is great, except the AUX does not work. I've found it, plugged everything I could find into it, but nothing works. I can't play any of my music because the CD changer only takes non-burned CD's and it's a pain in the ***.
I have a COMAND unit and everything else works, just not the AUX.
Help please!
Old 02-10-2016, 09:54 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Did you remove the command to check the cable to the Command? Sounds like you have a bad connection
Old 02-13-2016, 08:37 AM
OldMercsNeverDi's Avatar
2000 CLK320 Cabrio
Obviously you need to press SYS then AUX to play your content.
It's also a good idea to replace a stock cable with a shielded one.
Old 02-28-2016, 04:24 PM
happy18's Avatar
ml 350
Hi own a 2011 mercedes ml350 and when I try to start my jeep with the smart key that I always have used I now get this message (*key does not belong to this vehicle*)
What should I do...
Quick Reply: 2002 CLK 55 AUX won't work
