W208 430 - loose plug under seat
2002 W208 CLK 430 Coupe
Passenger seat in my 2002 CLK 430 hasn't worked since I bought it a few months back. I see under the seat there is a loose plug with 2 wires - blk w/ppl stripe and brn w/ blk stripe. Any idea what this harness is for and where it plugs in? I can't find a spot anywhere under there!
Bumping this to the top for a peek by someone willing to help.
I've searched high and low on the internet for a 2002 W208 passenger power seat wire diagram and get everything BUT what I am searching for. Google isn't as good as I hoped for in this instance.
The plug has a number on the side of it. 029 545 and below it 07 28. Just 2 wires in it. and it goes into the mesh of the main seat harness. Because I can't move the seat in any direction, I can't look closely at the power seat control under the seat.
I have checked the fuses in the trunk. I just replaced the passenger seat control panel on the door today. No luck. Seat doesn't auto glide when the seatback is moved forward. Headrest is in the down position all the time.
I do have a meter to check wires if someone can help me isolate the issue. Please help!
And what is this "door" seat control module that I keep seeing on Ebay? It's not the switch assembly. It looks like a small control box. Is there any chance this is also a culprit for the seat not working?
I have a skinny wire or two hanging under my seats but they both work. I initially had to replace a fuse after I already took the seats out by wrench. If you have the big plug in that clips in from side to side then you should have power. The little wires that I don't have plugged in and have no spot for I assume are for heated seats which isnt integration my cars feature package. Or they could be for the seats memory which I have never used, I was just happy to have them work again. I have heard the vacuum line from the pse controls each seat maybe check the line from the pse pump for the passengers side seat to see if it has a leak? Did u figure this out yet?
