replacing dead instrument cluster
Old 08-04-2016, 08:19 AM
riverdogg's Avatar
2000 clk 430, 2007 slk350
Is it possible to have a replaced instrument cluster(recycled) reprogrammed for the original car?
Old 08-04-2016, 08:37 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Yes----You need to replace the IC with the exact,repeat exact part number IC form a junker or you will be back whining---Oh what do I do, I think I just got screwed!!
Then if concerned you will need mileage correction!!
Old 08-04-2016, 06:30 PM
riverdogg's Avatar
Instrument cluster swap
Plutoe, thanks for the quick reply. Are you saying the correct part swap will
eliminate the "wrong Part Mwssage" I am warned about?.. Is there a way to reprogram the cluster to the original VIN as I've been told? Not concerned about mileage readings.
Old 08-04-2016, 08:47 PM
Plutoe's Avatar
1999 E300TD
The correct part number will solve that "Wrong Part Message"problem.
Regarding the potential drive authorization issue, I don't know if the VIN is stored in your specific model IC,however if it is, you first have to virginize the EEPROM, then place your VIN and mileage in----that process is not a DIY and there are loads of hackers that have the chip read\write tools and bin files to do the work.
If it's not stored, then all you have to do is mileage correction(if desired),but overall you need DAS Xentry.
Great news!!
Old 08-11-2016, 05:30 PM
riverdogg's Avatar
Plutoe, Many thanks again. I got an exact part # replacement dash cluster and installed. Totally operational, just with mileage of donor car. No big deal. Dash hasn't worked like this since 2002.
Old 08-12-2016, 01:28 PM
cindyclk's Avatar
you went since 2002??
Old 08-12-2016, 06:03 PM
riverdogg's Avatar
Started losing pixels in 2002. Gauges worked until 3-4 weeks ago. Now all back to normal
Quick Reply: replacing dead instrument cluster
