1999 CLK 320 Headliner Plastic Bezel
1999 CLK 320 Cabriolet
Upper Plastic Bezel Frame attached to Head Liner cracked.
Lower Frame Half - MB Part# 2087780133 is available. Problem is I need Upper Frame Half.
Is the Upper Plastic Bezel Frame available separately or am I on the hook for
a new Head Liner?
Any sources or guidance on how to repair?
Thanks,
a new Head Liner?
Thanks,
CLK 320 Plastic Bezel Frame for Convertible Headliner
Unfortunately, the thread you referenced is for Part# 2087770107 which is the External Frame the Convertible Glass resides in within the Canvass Top.
I'm looking for the Inner Plastic Bezel Frame that glues to the inner top portion of the Headliner. This part snaps into the top half of the inner rear of the metal window frame.
The lower companion Plastic Bezel frame - Part# 2087780133 - is available - that part snaps into lower half of the inner rear of the metal window frame but won't work for the top half as they are different sizes.
Do you know if the part for the Upper half of the Headliner is available or am
I stuck with getting a new Headliner?
Thanks,
Thanks,
The attached thumbnail shows the roof's rear window assembly / construction details.
The available part numbers should be in the MB EPC (electronic parts catalog) or from a dealer parts department.
I have a write up here on how I replaced my plastic frame. I also have a pic of both part numbers for the trim pieces.
https://mbworld.org/forums/clk-class...anvas-top.html
