Urgent Help Needed- CLK 200K Won't Turn Over
Old 10-17-2016, 11:22 AM
* Goliathus *'s Avatar
CLK200 Kompressor W208
Hello gyus. I'm having an issue at the moment with not being able to start my 2002 CLK 200 Kompressor.
This morning I took off a few bits (intake, supercharger & piping) to be able to remove the exhaust manifold as it had a crack in it. I got the manifold welded and put it back on. I assembled everything and had everything plugged in except for the electric fan. I started the engine and it ran fine with no exhaust leaks. I then turned it off, installed the fan and plugged it in. I closed the bonnet and the car will not start.
I put the key in and it registers it. When I turn it to start the engine nothing happens, not even a crank. Battery is showing 12V. All the fuses look fine. I tried disconnecting battery and both keys I got with the car with no luck.
I really need help on this one, anyone got any idea what it could be? Much appreciated!
Quick Reply: Urgent Help Needed- CLK 200K Won't Turn Over
