Custom parking sensors with OEM Display
Old 11-22-2016, 11:28 AM
adam95's Avatar
clk
Hello, is it possible to use w208 original display parking system display, and connect it to some aftermarket sensors/module? Or maybe its possible to fit aftermarket display in original space, so it looks clean? Any ideas? any photos? Thank you for any info
Becouse in my w208 i have all these displays but they don't work , becouse i think they are there only for looks. Even button in center doesn't light up
And when checking VIN those things shouldnt be there originaly
original display
aftermarket system
Old 11-23-2016, 02:17 AM
shadenfroh's Avatar
Making the original display work with an aftermarket system is a battle you're not likely to win.
Transferring the guts of the aftermarket display in the OEM housing is doable, but would require a bit of elbow grease.
Old 11-23-2016, 08:11 AM
adam95's Avatar
clk
and is it possible to make activation parking system with button in center console? becouse there is one in mine, but i aint connected to anything
Old 11-23-2016, 08:35 AM
shadenfroh's Avatar
The system is ON by default with every start. The button in the console disables it until you enable it again or shut the engine off.
The original front sensors activate below certain speed (10 mph?). Those in the back - only when reverse gear is engaged.
Wiring the rear system to the reverse lights is easy.
The front one you can wire to the switch so that it activates on press, but I imagine that to be quite frustrating for frequent use. I have no idea how you can make it work automatically below the mentioned speed limit.
adam95 (11-23-2016)
Old 11-23-2016, 11:32 AM
adam95's Avatar
clk
Okaaay , thanks , got all info i needed on this !
Quick Reply: Custom parking sensors with OEM Display
