Does the cruise control have an indicator light?
I bought a used 2002 CLK430 this summer and still learning about my car.
The cruise control works perfectely but is there an indicator light or dash light that tells you it's on? I've seen other models s with an orange LED "LIM" on the cruise control stick itself but I don't have that design.
Also, is there an indicator light that tells you if you are in "Summer/winter" mode on the transmission?
Dosent mention it in the owners manual at all.
Could I have a burned out light in the dash?
thanks!
thanks!
No indicator for cruise control.
If you've configured speed limit, a yellow light in the instrument cluster will light up when you reach it. If you have the LED in the cruise control stick, it should also light up at this point (I'm 99% positive about this, although I'm not going to go 160 km/h with my sh*t tires to test it ).
No indicator for transmission mode, just for shifter position.
steevil (12-02-2016)
