W208 audio system, need advice
Heeello , my friends!
So front door rear speaker, on facing the seat just died , and i get strange noises from it so. I need to decide. I just read on this forum on some thread that those speakers are pretty much useless.
*So is it worth replacing?
*Or can i somehow make their power go to door front speakers?
*What is best solution?
*What is best way to do it?
P.s. all speakers in front doors are changed to aftermarket and headunit aswell.
Thanks for any help or advice
Just went through an entire upgrade myself so things are still fresh. Audio is subjective, so disconnect or remove them and see if you're okay with the sound. If you are, then why change it.
IMO those speakers are very much all about fill and although they don't add much directly it does give you a bit more of an immersive sound. I removed the after market crap the PO had in there and went with this http://speakeraddict.com/vifa-tg9fd-...4db-75-vc.html and put a 300khz low pass filter on it.
I'm happy with the results.
I just replaced those old 10cm speakers with new aftermarket 13cm ones, had to drill doors a bit , but its fine.. Now feels like not so small subwoofer in car, seats give nice comfortable vibration becouse of lows
