Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W208)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-05-2002, 02:19 PM   #1
sungulent's Avatar
Drives: 2002 mercedes clk coupe
Send a message via AIM to sungulent
indash computer
ok fellas
i was driving the car this morning i see the light on the gas gauge is on
i check to see how many miles i can go with 1.8 gallons in the tank
every 10 15 seconds it changed from 22 miles to 38
is that thing really accuarate????
how da hell it goes down to 22 from 38???
can i trust the computer???
To remove this ad, register today or login if you already are registered!
__________________
BMWho??????
- 2002 clk320 coupe w/ jl audio system and pioneer tv
- 2002 ml 500 sport package 5 tvs and (set of 20" giovanna barleta)
sungulent is offline   Reply With Quote
Old 06-05-2002, 02:59 PM   #2
Drives: CLK55 and Yukon Denali
Re: indash computer
[QUOTE]Originally posted by sungulent
[B]ok fellas
It has done that to me. When I driveout of my house, I have a long drive where I have to drive slowly. As I get out of the gate and accelerate I find that mine fluctautes widely as it is computing your mpg based on your speed.
__________________
W208 CLK55 (all factory options but navi), 19" Maya STM's staggered, Lorinser springs, Lorinser roof wing, illuminated AMG door sills, flat hood badge, black birdseye/leather shift ***, titanium tint, color-matched side markers
Benzo is offline   Reply With Quote
Old 06-05-2002, 03:39 PM   #3
ktm
You need to stop looking at that damn computer and find a gas station.
ktm is offline   Reply With Quote
Old 06-06-2002, 12:16 AM   #4
sorlo's Avatar
Drives: E350, S320, Mini Cooper S
Send a message via ICQ to sorlo Send a message via AIM to sorlo
It happened to me once when the computer said 0 gallon and 0 miles. It was late at nite and none of the gas stations around was open. So I drove back home (make all turns without braking, and press the gas pedal very gently) and went to the closet gas station the next day, I was lucky enough to make it.
__________________
<img src="http://forums.mbworld.org/forums/attachment.php?attachmentid=34065&stc=1"</img>
2000 CLK 320 Brilliant Silver/Ash, K3, K4, COMAND, Illuminated door sills, 17" AMG style I, H&R sport spring - Sold
2003 John Cooper Works Mini Cooper S, Dark Silver/Black, Leather, Sport, Premium, and Cold weather package - Sold
<b>New Status from Poch: Masters of the Beast!</b>
<img src="http://forums.mbworld.org/forums/attachment.php?attachmentid=37667&stc=1"</img>
sorlo is offline   Reply With Quote
Old 06-10-2002, 09:22 AM   #5
Ahmed's Avatar
Drives: C63 AMG
that happens... cause the damn computer does it the hard way.
it analyses your driving style, then the consumption, then gives you the result of your remaining fuel based on that.
this also means that the results continuosly changes cause your driving style changes by the second. Especially when ur cruising... u get low consumption, therefore more miles left. When ur in traffic constantly accelerating, then your consumption rate is high, therefore less miles left to go!!!
__________________
2009 Lexus GS460
2013 Mercedes Benz C63 AMG - P31
Ahmed is offline   Reply With Quote
Old 06-10-2002, 09:38 AM   #6
karl k's Avatar
Drives: 2002 CLK 55 AMG Coupe ;)
Quote:
Two sceneriors:
1. The computer is like a Las Vegas gamble: Sometimes you win, sometimes you loose!
2. It reads your brainwaves.
a) The upper number is what you wish/hope for.
b) The lower number represents what the Las Vegas gamble might be -- at best.
Seriously, I had a bunch of MBs, they all fluctuated.
Had also a 2001 Vette, -- same fluctuation...just don't take these inaccuracies too seriously; it's part of life, the stock market...it fluctuates...usually down the more you drive.
__________________
2002 CLK55 ////AMG
brilliant silver & charcoal nappa
GPS Comand & Escort 8500
karl k is offline   Reply With Quote
Old 06-10-2002, 10:54 AM   #7
The computer just guesstimates how far you can go based on 2 things:
1) how much gas there is in the tank -- this itself isn't completely accurate, and the less gas you have, the less accurate it is, as it approaches the limits of the measuring device, and
2) it tries to guesstimate how you're driving...i.e. if you're driving more aggressively it will figure less miles per gallon.
So you can see as these two variables change so will your mpg. So if you were punching the accelerator, and now are driving more normal, your mpg will probably go up.
Or if you make a sharp turn, the sensors might think there's less gas in there as you move around.
Safet is offline   Reply With Quote
Old 06-11-2002, 06:44 PM   #8
Drives: CLK 320
The computer also leaves a small contingent of 1.2-1.9 gallons that it doesn't tell you about.
If you take your gas tank down to 0 gallons and 0 miles left, and then fill up your tank, you will notice that you can only pump in 14.5 to 15.2 gallons.
__________________
2002 CLK 320 - Brilliant Silver, K2,K3
Euro Command
DVD player connected to TV Input
Shah is offline   Reply With Quote
Old 06-11-2002, 07:07 PM   #9
karl k's Avatar
Does anyone know the small (3mm diameter) round dot located 1/2 inch below the center pivot point of the gas needle indicater?
Is this a second gas indicator light, which comes on when the needle is on zero and computer tells you zero miles to go, when you actually have about one gallon gas left?
__________________
2002 CLK55 ////AMG
Tags
computer, indash, make
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
