A/B Service?
A/B Service?
Can anyone tell me what exactly is included in the service A and B on the CLK?
I know it is all listed in the back of the service booklet but mine is written in German!
Can anyone help me out, im due a service A, but may just get a service B because ive only recently got the car and want to make sure everthing is cool with it.
Cheers
Cheers
AMG, Ferrari, Lexus
A-Service - First visit at 10,000 miles or 1 year; then every 20,000 miles or 2 years
What is Checked:
Interior
· Function Check
· Warning and indicator lamps, illumination and interior lighting
· Windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness (remove 1 front wheel)
· Check tires for damage, condition
· Correct tire inflation pressure
Engine Compartment
· Engine oil and filter change
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield Washer System
· Brake System
· Battery, check and correct fluid level; check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
· Battery, check battery condition
B-Service - First visit at 20,000 miles or 2 years; then every 20,000 miles or 2 years
What is Checked:
Interior
· Function Check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of brake discs front/rear
· Check brake pads for lining thickness front/rear
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Brake system
· Power steering
· Active Body Control
· Windshield washer system
· Check condition of poly-V-belt
Trunk
What is Checked:
Interior
· Function Check
Wheels, brakes
Engine Compartment
· Brake System
Trunk
What is Checked:
Interior
· Function Check
Wheels, brakes
Engine Compartment
· Brake system
· Power steering
Trunk
