CLK 500 Transmission problem.
2005 CLK500 Coupe
I have a 2005 CLK 500, the only problem i have had with the car is that the sunroof is not one touch, i have to hold it to close it. put 15000 miles on it so far.
My brother has a 2005 CLK500 also, he put only 3000 miles on it so far. he was driving and realized when he breaked and the car was at low speeds it downshifted and gave a harsh jerk before it came to a stop. he took it to the dealership and they changed some parts of the transmission but same problem was there, they then changed the entire transmission of the car, and then it was running fine, but the breaks were weaker, you had to push the breaks harder for it to stop, so now he has given the car back to the dealer and they are putting new breaks and new break lines on the car.
Has anyone else had this problem at only 3000 miles.
'05 CLK500 & '05 C230
Yep, mine is doing the same thing. Though it only seems to do it when the car is cold in the mornings (not that it gets very cold here). If it becomes a problem outside of the first 5 minutes of each day, I'll take it in. But as it stands, it doesn't bother me too much. Oddly enough my wife's C230 behaves the same way.
The sunroof should open one touch. If it's not, you should take it in.
I had the same problem with my brand new CLK 500. It's a problem with the transmission chip - see the thread "Gear Shift Hesitation in CLK 500 (2005)" in the forum dated 5-25-05 to see everyone who also had this problem - almost everyone had to take it back to the dealer and replace the chip/transmission.
2005 CLK 500
2005 Clk 500 Sucks!!!!!!!
I recently purchased a 2005 CLK 500, and wasn't awared that it come with a vibration package. The car jerks, jumps and grinds when I accelerated or decelerated. Especially when I would slow down to a stop. And it's not subtle, I can feel it. Mannnn...... the car has it own moves, I'm telling you. Mercedes are doing too much, and trying too hard to beat other makes. And guess what? They SUCKS!!! Six speed transmission was doing fine, but no....had to come up with a seven speed transmission. Now, all the Mercedes with a 7 speed transmission are F/UP. My babied already had a transmission replaced when it was 2 months old. The car is 6 months old now. The problem is still occuring. I asked the mechanics there, what is the deal here, why can it be fixed? Sadly, I was stated by one of the mechanic, that is how the 7 speed transmission works. Basically saying "DEAL WITH IT". I am filing a complain under the Lemon Law for my car, and the arbitration hearing supposedly is this coming Tuesday Nov. 1st. I got a called from them this morning saying that there is an attorney represent them, and their witness ( Mercedes Rep) is in the hospital having somekind of surgery. Therefore, the arbitration hearing has to be rescheduled. Anyways, if anyone knows anything about how this arbitration works, please assist me, I am so lost. Thank you!!!
2005 CLK 500
2005 CLK 500
CLS, C
dude, i get the same thing with my cls500... and it only happens in the first 5 minutes when i turn the car on usually in the morning...
2005 CLK 500
Yeahh, mine does the same thing, whenever the car at a cold start. I already had a transmission and a control module(?) replaced three months after I purchased the car. I have this car for 6 months now. The problem is still occuring. The vehicle jerks, jumps, and grinds. Did u have ur transmission replaced too? Is the problem gone? If i when the case, i'm going to get me a cheaper car, atleast i dont have a hight expectation for it. I hate to walk away from Mercedes, but i've learned that looks aren't equal to quality. I used to owned a C230 coupe, and have no problem with it. That was y i traded it in for this $60k LEMON. I'm so disappointed, and furious in Mercedes. I WILL NEVER BUY ANOTHER MERCEDES.
2005 CLK 500
Yeahh, mine does the same thing, whenever the car at a cold start. I already had a transmission and a control module(?) replaced three months after I purchased the car. I have this car for 6 months now. The problem is still occuring. The vehicle jerks, jumps, and grinds. Did u have ur transmission replaced too? Is the problem gone? If i when the case, i'm going to get me a cheaper car, atleast i dont have a high expectation for it. I hate to walk away from Mercedes, but i've learned that looks aren't equal to quality. I used to owned a C230 coupe, and have no problem with it. That was y i traded it in for this $60k LEMON. I'm so disappointed, and furious in Mercedes. I WILL NEVER BUY ANOTHER MERCEDES.
CLS, C
Originally Posted by cutechik501
Hi, thanks for replied
you have to understand that you have a v8, and its a comlicated v8 that mercedes makes... i try to let my car warm up for a minute or 2 before i start driving... and if i dont have the time, i press on the gas very gently, untill i feel like the car has warmed up...
Grinding and jerking is definetly not a normal characteristic after a cold start/driving. The trans is designed to hold first gear longer when the car is cold to help the cats heat up quicker.
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
2005 CLK 500
Yeahh, i'm looking for an attorney specialize in lemon law rite now, but no luck. Do u have any suggestion? Some input would be very much appreciated.
2005 CLK 500
So, is ur car still doing the same thing? I refuse to put up with this stupid transmission failure. The car note is too high to be dealing with this issues. Mercedes had let me down.
2005 clk 500 cab, 2004 Bmw 530I, 2008 E350 4matic, 2010 C300 4matic
transmission problem
I to have a 2005 clk500 with the same problem, the harsh down shift only occours in low gear when comming to a complete stop, it usualy only happens in the morning when the car is cold but it has happend before during the afternoon when the car is warmed up. I havent told the dealer about it should i now that i see many people experence the same problem?
2005 CLK 500
Mercedes Sucks!!!
CLK55 AMG 2006 Cabrio, BMW M3 2008 DTC Cab new (M3 e46 SMG 2003 Cabrio Sold), BMW X5 tt Diesel 2008
Hi All,
We have the same problem in Australia, I know of one CLK owner here who has been driving around in loan Smart Car for 3 weeks because his 7 speed auto gearbox in his CLK is not yet repaired. It's a wonder someone there in the US has not started a Class Action. If you do end up going to a Tribunal Hearing you want to ask them to produce the history for all 7 speed gearbox warrantee repairs. I bet there will be some ducking & weaving will then go on.
This 7 speed box might be alright with a small motor but I don't thing it can handle being pushed to hard. Anyway a 6 speed auto is enough, I could not stand all those gear changes.
Robertus
Robertus
When the 7 speed works properly the gearshifts are almost seemless. Unfortunately, as with most new complex products a year or even two is needed to get all the bugs out.
MB's problem is they ship cars with know issues which end up in the dealer's service dept multiple times therefore pissing off the consumer which in-turn kills MB's initial quality ratings. What a system
