Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-15-2007, 11:16 AM   #1
Drives: W204 C63 / W212 E63
Talking TV Tuner for CLK???
I've added a Euro Command to my 2006 W209 CLK350 and now want to add a TV Tuner. I've read that W211 and W220 TV Tuners will work in a W209, could anyone confirm? Will the following models work in my car?
A 211 820 05 97
A 211 820 14 97
A 211 870 27 62
A 221 870 19 89
Also, I understand that i need to purchase the power wiring harness for the TV Tuner - does the harness include the MOST cables? Could anyone confirm if I need to add an additoinal MOST cable from the amplifier to the TV Tuner and then TV Tuner going back to the Command?
Finally, does ANYONE have the part number for the wiring harness?
Thank you!
To remove this ad, register today or login if you already are registered!
shimmers is offline   Reply With Quote
Old 01-15-2007, 11:21 AM   #2
SUNILP's Avatar
Drives: 2003 c320, 2002 s500, 1992 300SD
Send a message via AIM to SUNILP Send a message via Skype™ to SUNILP
220 tuners will NOT work. The one you need has a brown FAKRA connector on the tuner itself I believe it's the 1497 you need. Wiring a MOST based tuner is pretty simple. You can use the Satellite radio Fiber optics to plug into the tuner first. Next, you'll need the power connector. It has 4 wires on it. Power (constant), ground, turn on, and antenna power. You can use the satellite radio power connector for this as well. You will have to get a amplified antenna with the correct connector also. You will have to run a FAKRA coax wire to the front of the car and plug it to the green fakra connector behind the comand unit.
__________________
Sunil <br>
1993 300SD Updated
2004 S55 AMG
2003 C320 with supercharged s55 engine
2004 E320 Wagon with OM648 Diesel Loaded
2008 ML320 CDI Package PIII
SUNILP is offline   Reply With Quote
Old 01-15-2007, 11:43 AM   #3
Quote:
Hey Sunman, thank you for your quick reply. 1497 has the FAKRA but the 0597 does not - however, I only need the FAKRA for the TV antenna, right? Because I plan to use the TV Tuner just for RCA Video input (for DVD player, etc.), I won't need an antenna which means that I can get by with the 0597 model (since it has the same optical/4 pin power connector.
Also, using the Satellite radio fiber optics, you mean that i take the optical input from my amplifier and connect it to TV Tuner optical in first, and then another optical cable from TV Tuner out to the amplifier in, right?
By the way, could you let me know where I can purchase the satellite radio fiber optic and satellite radio power connector? What are their part numbers?
Thanks!
Old 01-29-2007, 11:54 AM   #4
Hi, could anyone confirm if the tv tuner model A 211 820 05 97 will work with my 2006 CLK? I see on the Germany ebay that this model is compatible with W209 CLK but I don't know if I can trust them. The only difference is the brown Fakra connector on the back which connects to the green Fakra on the back of the Command - what is this needed for? Please note that I don't plan to use the antenna nor TV but just the RCA inputs.
Finally, I think I can just tap into power lines of the amplifier but for the optical lines, can I just use another optical line from the amplifier to the TV Tuner (to add it to the ring). It seems like this way I can simply avoid running wires from the trunk to the front Command.
Anyone??? Thanks.
Old 01-29-2007, 12:10 PM   #5
Whats the best place to order all this stuff? I'm a newb and also wanted to know if we can use the in dash dvd player for viewing dvds? thanks
stingnyc is offline   Reply With Quote
Old 01-29-2007, 10:41 PM   #6
MARK CUMMINS's Avatar
Drives: 209/W210 Estate /W211 modded by MBENZNL
Quote:
www.mbenznl.com
__________________
Why is there the Need to Eliminate Responsibility for ones Actions by Blaming Everyone Else
MARK CUMMINS is offline   Reply With Quote
Tags
14, 2006, 211, 500, 820, 97, a, activate, antenna, clk, connect, fakra, tv, tvtuner, w209
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
