Instrument cluster removal
Does anyone know how to remove the factory instrument cluster out of an 05' clk500? I see slots on the bottom corners, special tool to stick in there to release it?
2007 E550, 2002 C32,2004 S430,2001 E320
w209 instrument cluster
MB sells the tool its called instrument cluster removal tool. Its set of 2 pics with handles. All you do is stick in the holes and the end of the tool has a hook you turn 1/4 of a turn and pull together with both hands on both hooks.
04 CLK 320 > CLK32K
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
One bit of advice, check with your local dealer or mail order Mercedes dealers. Good chance they'll be cheaper than Ebay.
MBworld Guru
This is for the W203, but the W209 is the same. The first few pics show you what you are doing and what the homemade tool looks like:
http://benzbits.com/w203/cluster.html
320, amg, clk, clk55, cluster, dash, homeade, hooks, instrument, instrumentcluster, insturment, mercedes, moreeclass, panel, removal, remove, w209
