Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK-Class (W209) 2003 on: CLK 270 CDI, CLK 200K, CLK 200 CGI, CLK 240, CLK 320, CLK 350, CLK 500, CLK 550 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: CLK 500
CLK500 Transmission Service question
__________________
#2 |
when is the transmission service due for a 2003 e320? same mileage?
#3 |
Drives: 2005 CLK 500 - 1999 Prelude was 505whp (stock now)
When I was getting pricing from two dealerships, they both were around $400 for the tranny filter replacement and 6 qts of tranny fluid. Ending up buy the tools and doing the service myself. Car's transmission felt much better with smoother and crisper shifts.
Recommend service interval is 60000 km or 39000 miles. I ususally do mine at 50000 miles. The 5 spd tranny on the e320 can be flushed and requires 12 qts to do the flush and fill. |
#4 | |
Drives: CLK 500
Quote:
__________________
#5 |
Drives: CLK 500
Any idea on why some dealers change the filter and some don't?
__________________
#6 |
Drives: 2003 CLK 320
cuz they like to cheap out?
can you request to change the filter?
__________________
current mods: audio, 35% tint, wheels, v1, air freshener, vogtland springs, koni yellows, c32 amg brakes, ss lines, 3 slat gloss black, future mods: exhaust, black series sways, rear amg lip in black (storage), gloss black vinyl roof (when i head to LA to visit Don) |
#7 |
Drives: '05 C200K SS, '05 Kleemann CLK500K & '92 Z34 5sp (track car in Canada)
My 500 is in the MB shop right now waiting for a trans shift module (coming from Germany) so I had them do the full trans service while they were at it. Complete flush, new oil trans oil (obviously) and filter is $500USD on the nose here. Pricey but with the searing heat here one is foolish not to maintain the oils well ahead of schedule.
__________________
Kleemann S8 CLK500< Kleemann supercharger, cams, headers & tune | H&R springs and sways | Koni adjustable suspension | Brembo GT BBK (6F/4R piston, slotted floating composite rotors) | Carbon fiber front lip & rear diffuser | Custom Magnaflow exhaust, quads with 100 cell cats | GPT pulley | Vorsteiner carbon fiber rear spoiler | Quaife LSD | E55K airbox & kevlar tubes | Magnecor KV85 wires | 360 Straight 5ive wheels, carbon fiber | Mods/build thread |
#8 | |
Drives: CLK 500
Quote:
__________________
#9 |
Electrical. The car went into 'trans limp in mode' two days after I bought it (how's them apples?) so i took it into MB to have it checked. They said the code had been thrown a few times, did the diagnostic and it came up as a faulty module, $750USD to replace and they don't stock it in the Middle East so it's on it's way from Germany. I decided to have some other work done on the car while it's in as well. I never have and never will cut corners on maintenance, in fact, I'm always doing things ahead of schedule here.
__________________
#10 | |
Drives: CLK 500
Quote:
__________________
#11 |
Drives: 04 CLK500, 05 BMW 545i & a Rickshaw like Supafly ;)
I would get a drain and fill not a flush at your mileage.
#12 |
Drives: CLK 500
Any particular reason why ? I spoke to a service rep and they informed me that in some cars with certain age and miles they would do a flush and then some they wont mainly not to cause any more damage. Last thing I want is to get a flush and then my tranny goes.
__________________
#13 |
Drives: CLK 500
Now I'm confused. Do I need a complete drain, flush and fill or just a drain and fill
__________________
#14 |
Drives: Mercedes Benz E500 4MATIC
A flush will be fine... I just did one at 98,000 currently at 109,000 no problems whats so ever.... Oh while your doing the trans flush you might as well have the differential oil changed too.
#15 |
flushing a trany can break old deposits off and they will go thru the trany some times causing problems when they block up small holes that the trans fluid goes through. It's not a perfect science. You could be okay or it could cause problems, no way to know. I drained mine at 55 will do it again at 85,000. I was told the majority of it was changed although some fluid that was sitting in the tranny itself stayed in. 2/3s of it is new.
#16 | |
Drives: CLK 500
Quote:
__________________
#17 |
No, not really, it was shifting fine before and after.
#18 |
Drives: CLK 500
__________________
#19 |
Drives: clk500
also just fyi they just came out with a new oil for the tran
i was told by the forman it is alot better and if u drain every 30,000 u will never have any thing go wrong
__________________
2003 CLK500-139,000 MILES AB-RACING: V2-FULL INTAKE,COOLING SETUP,FULL EXHAUST KLEEMENN HEADERS EUROCHARGED ECU/TCU AMS PULLEY K.SPORT COILOVER AND WEIGHT LOSS USED FREE FLOWING THER. FOR SALE http://www.mbworld.org/forums/engine...hermostat.html F/S 16IN RIMS http://www.mbworld.org/forums/wheels...benz-rims.html |
#20 |
Similar story here, I drain every 25K and flush every 50K on my C class and will do the same with my CLK now.
__________________
#21 |
Drives: CLK 500
So I'm at 60k and i doubt my car has ever had the tranny service preformed so should I preform the full flush or just a drain and fill?
__________________
#22 |
Personally, I'd do the flush but I understand what BadDebt is saying. If you had 100K on it, driven like hell, brake stands and in a really hot weather location it might be a different story. MB trans fluid is very, very good - it's probably unlikely that you'll have any issues with deposits.
Have you owned the car since new?
__________________
#23 | |
Drives: CLK 500
Quote:
__________________
#24 |
I would do just the drain and fill. Like Baddebt said, a drain and fill replaces 2/3 of the fluid anyways (6 liters). Another thing is definitely have them change the transmission filter.
#25 |
Drives: CLK 500
Thanks for the input Quaalude
__________________
| Tags |
| 03, 2005, 500, change, clk, fill, filter, flush, maintenance, mercedes, nyc, problems, service, tranny, transmission |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
