Sign in using an external account
| CLK-Class (W209) 2003 on: CLK 270 CDI, CLK 200K, CLK 200 CGI, CLK 240, CLK 320, CLK 350, CLK 500, CLK 550 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Remove end cap from axle?
#2 | |
Drives: Slk55, Clk500 Cab., C350, Civic
Quote:
Yes, you can remove that cap it but why do that when you can just get the right spacer for ONLY the front. The front spacer will have a long cap that would cover that cap but some still require to remove the stock cap.
__________________
#3 |
H&R has specific part #'s for front and rear spacers. Make sure you have the correct part #. What size H&R's are you trying to install? I have 10mm front and rear and didn't have a problem.
http://hrsprings.com/scripts/appguid...Trak&MakeID=25 |
#4 |
I don't really want to take the cap off, but I can't find a spacer that will fit over the cap. The spacers I currently have in hand are the H&R 30556659 that they say are for the FRONT of a 2005 CLK on their web, and over the phone with H&R. However when I try to put it on it gets stuck. The main spacer fits on fine, but there is a slight taper from the 66.5mm center bore in to the thin metal protuding lip, and it is this thin lip that is slightly less than 66.5 that gets stuck on the cap.
Dynaomite05, I have heard good things about H&R and figured I had found my solution but these sure don't seem to fit. I am thinking if I can get the cap off to get the spacer on, I can put it back on after the install. Thanks for the replies. |
#5 | |
Quote:
Sounded like you has never seen one for the front. Here's what it look like.
__________________
#6 |
Klinh, you are correct. I have never seen spacers like that. Pretty slick.
Where did you find those? I just checked the Tuner Shop site and just saw the standard System 2 spacers. Didn't see the ones you had a posted a picture of (2_d). Any chance you have a link I could order from? |
#7 | |
Quote:
I got the pic from Ebay but I recommended H&R brand. If you do order it from H&R, read the side NOTE that specified for front spacer only.
__________________
| Tags |
| 30556659, axel, axle, cap, caps, center, clk500, end, endcap, front, metal, removal, remove, removing, w209 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
