Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-01-2011, 06:12 PM   #51
ludwig14's Avatar
Drives: 2004 CLK500
I guess I may be wrong here but it has the correct fitment in the center In terms of bore for the hub
To remove this ad, register today or login if you already are registered!
__________________
ludwig14 is offline   Reply With Quote
Old 06-01-2011, 07:13 PM   #52
Mka77's Avatar
Drives: 06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Mike Amberson
The spacer should fit snug on both the wheel bore and hub bore if that helps.
__________________
Mike
Mka77 is offline   Reply With Quote
Old 06-01-2011, 07:48 PM   #53
dynomite05's Avatar
Drives: 04 CLK 320 > CLK32K
dynomite05
Does your spacer have a lip on it or is it just flat? Take them off and the vibration should go away.
dynomite05 is offline   Reply With Quote
Old 06-02-2011, 01:30 PM   #54
Drives: 2003 c240
harold coronado
Send a message via Yahoo to hcoronado
any of you guys running 18x8 with 37 offset? I have a guy who is interested in buying a set of rims with those measurements. he's got a 2003 clk320 and i dont want to sell them if he is going to have problem.
thanks for the help
Harold
__________________
Cubanite/Pewter|Black Leather|S Class Tail Lights|Tein Springs|Koni Sport shocks|AMG sway bars|05 c230 facelift|Projector Head Lights & 6k HID Xenon=Present|6K HID Fogs|5k LED city lights|smoked Markers|JBSPEED Rear Spoiler|19" rims staggered|Flat Hood emblem|Avic Z120BT + steering wheel control|iPod+Bluetooth|12w6v2|JL Audio 500/1|Focal component|JL Audio 300/4|05 c230 Brakes|L.E.D. Interior lights|Magnaflow+dual tips|35% Tint|Vinyl Roof by Don Nguyen|Eurocharged Tuned|Suvneer CF front lip|
hcoronado is offline   Reply With Quote
Old 06-02-2011, 02:04 PM   #55
Mka77's Avatar
Mike Amberson
Back should be fine. Fronts might be a little suspect at et37.
__________________
Mike
Old 06-02-2011, 02:10 PM   #56
Drives: 2003 c240
harold coronado
Quote:
do you think that using a 5mm spacer to bring the offset down to 32 will work?
he is not opposed to using spacer as long as the bolts are the right size.
__________________
Old 06-02-2011, 05:33 PM   #57
Mka77's Avatar
Mike Amberson
32 would be fine.
__________________
Mike
Old 06-02-2011, 05:42 PM   #58
dynomite05's Avatar
dynomite05
The smallest size spacer that is hubcentric is 10mm. A 5mm spacer up front will cause vibration.
Old 06-02-2011, 09:16 PM   #59
EuroTra$H's Avatar
Drives: 05 CLK500
Quote:
so true... a 5mm will drive you crazy with the vibration and that goes for the rears as well.
__________________
Livin the Dream
EuroTra$H is offline   Reply With Quote
Old 06-07-2011, 01:29 PM   #60
Newjd2's Avatar
Drives: 2004 CLK 500, 2004 Honda Civic
As promised...
Wheel: Gloss Black w/ Mirror Finish Lip Mandrus Millennium
Width: Front-8.5"
Rear-9.5"
Offset: ET25 all around
Tire Make: Falken 452
Tire Size: Front-235/35/19
Rear-265/30/19
No Spacers or camber kit
Suspension: Eibach Pro Kit (1.2" drop all around)
Spring Pad #1
Angelo
***Official Wheel/tire/stance Fitment Thread***-merce7.jpg   ***Official Wheel/tire/stance Fitment Thread***-merce3.jpg   ***Official Wheel/tire/stance Fitment Thread***-merce5.jpg   ***Official Wheel/tire/stance Fitment Thread***-merce6.jpg   ***Official Wheel/tire/stance Fitment Thread***-merce.jpg
***Official Wheel/tire/stance Fitment Thread***-merce8.jpg
__________________
2004 CLK 500
..#2..
Newjd2 is offline   Reply With Quote
Old 06-07-2011, 03:12 PM   #61
dariusf's Avatar
Drives: CLK320, E350 (2011)
Click the image to open in full size.
Monarch EURO 63 RS
19x8.5 32mm offset - 3mm spacers = 29mm
19x9.5 35mm offset
225/35/19 Toyo FZ4
255/35/19 Bridgestone Potenza RE050
some generic 3mm spacers on the front. This was to give the shock a little bit more room and also the bolts I had were a bit too long so that allowed me to use them.
Lowered with Bilstein PSS9 Coilovers
No camber kit for now
Before mounting place the bolts in to the wheels and measure the part sticking out. For me the thread sticking out is 5/8" (16mm) both front and back. Any longer and I would not be able to tighten up the front and in the rear I was hitting the E-break with the knocking sound.
I think I could also lower a bit more but the look is fine now and do not want to deal with potencial rubbing issues. I might drop the front by another 1/2 inch and will try to add 10mm spacers in the rear.
__________________
dariusf is offline   Reply With Quote
Old 06-11-2011, 10:56 AM   #62
Drives: CLK550
Where are you guys finding 32 offset wheels? I looked on Power Wheels Pro and everything seems to be a 35 offset which is fine for my CLK550 rear but not the front. They have a couple 32 offset but they are 18x8 and do not have matching 35 mm offset for the rear.
I would prefer not to use spacers if I do not have to.
I am looking for an 18 8.5/9.5 setup.
woogs is offline   Reply With Quote
Old 06-11-2011, 11:05 AM   #63
dynomite05's Avatar
dynomite05
Why not go with a low offset all around? ET32?
Old 06-11-2011, 02:23 PM   #64
EmE247's Avatar
Drives: Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Here's my fitment question...
I have a 2011 W212 / E350.
I am contemplating running...
Front - 20x9 ET 43 Tires - 245/30/20
Rear - 20x10.5 ET 48 Tires - 285/25/20
Looking for a classic/aggresive stance. I have no qualms about using spacers.
Yay or Nay?
EmE247 is offline   Reply With Quote
Old 06-11-2011, 05:11 PM   #65
Mka77's Avatar
Mike Amberson
Yay or Nay?
You might be better served asking in the 212 forum. Good luck
__________________
Mike
Old 06-11-2011, 05:38 PM   #66
Drives: 2006 CLK 500
Send a message via AIM to mark1281
I figure I might as well post mine too.
2006 CLK 500
Modulare M11c 3 piece Brushed Aluminum face with Chrome lip
19 x 8.5 front 2" lip
19 x 9.5 rear 3" lip
Toyo Proxes 4
235/35/19 front
265/30/19 rear
No suspension mods.
__________________
2006 CLK 500
mark1281 is online now   Reply With Quote
Old 06-11-2011, 05:43 PM   #67
EmE247's Avatar
I did.
Did a search and found this the only wheel fitment sticky. Figured wouldn't hurt asking here for any of the pros out there that might know.
Old 06-11-2011, 05:44 PM   #68
dynomite05's Avatar
dynomite05
The thing is we don't know the offsets that work with the 212.
Old 06-12-2011, 12:45 AM   #69
lowpost's Avatar
Drives: 2009 GL450 . 2004 CLK 500 . 2001 4.4 X5 (SOLD)
I did.
The purpose of this thread is to share wheel/tire fitments and suspension setups for THE W209 CLK.
You probbaly would have better luck searching in the 212 forum or creating a thread there and asking your questions. Good luck.
__________________
lowpost is offline   Reply With Quote
Old 06-24-2011, 10:15 PM   #70
Drives: CLK 320
Anyone running ET32 in front? I am looking at the Avarus AV6 in black w/machined lip and it only comes in ET32 front, and ET35 rear (19 inch)...so curious about how that works...TIA for any input.
billyhead1 is offline   Reply With Quote
Old 06-25-2011, 06:53 AM   #71
dynomite05's Avatar
dynomite05
You should be fine. You can see in my post on page 1 that I ran ET35 all around at one point with my stock 320 brakes with no problems. Only thing is you might want to push them out a bit with spacers.
Old 06-25-2011, 09:43 AM   #72
Mka77's Avatar
Mike Amberson
I am running a 32 up front.
__________________
Mike
Old 06-27-2011, 08:46 PM   #73
JHouse's Avatar
Drives: 2004 CL55 AMG
2004 Mercedes Benz CLK 320 wheels 17" x 8" - 5-112 bolt pattern - 35mm offset - Tires 225/45-17 (Same as the stock fronts - 4" sidewall and 25" diameter)
Here are the wheels: http://www.oewheelsllc.com/Wheels-fo...52695-2-1.html
Here are the tires: http://www.discounttiredirect.com/di...tus+V4+ES+H105
4 new wheels and 4 new 50,000 mile Hankooks
I LOVE it!
Here is the car:
__________________
"I prefer dangerous freedom over peaceful slavery."
-- Thomas Jefferson
Joe --- It still feels like new every time I get in it.
And 90% of your questions are answered here: https://epc.startekinfo.com/epc/home.jsp
JHouse is offline   Reply With Quote
Old 06-27-2011, 08:52 PM   #74
dynomite05's Avatar
dynomite05
You're running 225 all around?
Old 06-27-2011, 08:53 PM   #75
JHouse's Avatar
Yes I am. Now I can ROTATE them. Remember I'm the guy who bought a used car with 3 wheels of the same size and one rear wheel wider by an inch. Going to sell those now. They have good rubber on them too.
One more:
__________________
-- Thomas Jefferson
Tags
2009, 265, 320, area, clk, factory, fitment, forums, lancer, pensacola, pics, rims, series, tire, tires, wheel
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
