SL55 wheels on my CLK, some questions...
w209
Hello. I want to install SL55 AMG (multispoke) wheels on my CLK. Will I need something special like other bolts, or will they fit directly?
w209
1 Post
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
There is a good chance you may need either a longer or shorter bolt going from one wheel to another. You will just have to measure what you have now that sticks out the back side (bolt wise) of your OEM wheels and compare the length to the SL wheel. The ball radius should be the same. The rear et is ok. The front being a 30 might be close depending on the the tire size you run. Hope that helps some.
Sorry to rehash old post and dumb question but will the sl55 amg rims clear clk63 big brakes? I'm assuming their offsets clear pretty good. But do they stick out too much - I don't want to rub outside either.
