Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 12-09-2011, 04:53 PM   #1
Super Moderator
Glyn M Ruck's Avatar
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
Exclamation DIY 722.9 7G-tronic 7-speed automatic transmission service thread
Johnand's excellent DIY 722.9 7G-tronic 7-speed automatic transmission service thread with WIS documents attached:
To remove this ad, register today or login if you already are registered!
__________________
Llandudno, Cape Town, South Africa
Glyn M Ruck is online now   Reply With Quote
Old 12-09-2011, 05:02 PM   #2
Super Moderator
Level is checked by spill over method at correct temp from beneath. Use IR thermometer or similar on pan to take temperature as an alternative to Star DAS.
The use of 236.14 fluid is mandated. Ryder fleet products have by far the best deal on this product by Shell at under US$ 6 per quart. Most dealers are charging over $20/quart. The Shell product is fully approved. Many use Fuchs Titan 4134 as well.
See description. It is Shell product in a Shell container - Pennzoil is owned by Shell. Many have confirmed correct product in Shell packaging on receipt.
http://www.ryderfleetproducts.com/ry...oductDetail.do
Click the image to open in full size.
__________________
Old 12-09-2011, 05:05 PM   #3
Super Moderator
Just cobble up a large syringe/oil pumping arrangement with a flexible tube on it & get the car on a hoist. All you are doing is replacing a workshop air operated pump. Observe temperature requirements in the attached pdf.s to Johnands DIY thread and above. Read pdf's in detail - all will be plain.
__________________
Old 01-13-2012, 10:23 AM   #4
Drives: 2004 Mazda6, 1993 RX7
Found this detailed description of the 722.9 auto trans on the web. Likly already in Johnands thread. Includes some off MB doucument pages, posted by Glyn as necessary.
MERCEDES-automatic-transmission-722-9
__________________
ex's 2008 C300 4Matic, Luxury + Sport Grille
kevink2 is offline   Reply With Quote
Old 01-13-2012, 10:39 AM   #5
Super Moderator
Yep - That's one of the training programs for techs that I got from MB & have used.
__________________
Old 01-15-2012, 10:40 AM   #6
Super Moderator
Approved fluid update
__________________
Old 01-21-2012, 11:36 AM   #7
Super Moderator
W209 - Gentle Warning - Service your 722.9 Transmission every 39K miles 60K Km's
W204 - Gentle Warning - Service your 722.9 Transmission every 39K miles 60K Km's
W203 - Gentle Warning - Service your 722.9 Transmission every 39K miles 60K Km's
__________________
Old 05-04-2012, 08:03 AM   #8
Drives: 2008 C300 Sport, RWD, US
Glyn
I just found in another thread where someone who just had a transmission service found that he was charged for 6 quarts of fluid and the concensus is that they must have not done the torque converter as it should have taken 9 quarts.
Does this sound right and does it apply to my 2008 C300????
Transmission service done, but ........
JimPap is offline   Reply With Quote
Old 07-17-2012, 01:36 PM   #9
Drives: 2008 C350-Sport-AMG-Active Agility Pack + B170 2008+Mitsibishi+Mazda
Not all W204 has the TC-Plug
I querried my C350 and was told not all W204's with this transmission comes with the TC-Plug, so 6L Fluid.
I was invited to bring car and they show me, I will do that.
What now ?, is my question.
__________________
Moto_Guzzi is offline   Reply With Quote
Old 07-17-2012, 08:31 PM   #10
Super Moderator
Your car will have a TC drain plug.
__________________
Old 07-18-2012, 02:53 AM   #11
Thanks, they offered to redo the job if there is a plug.
__________________
Old 07-18-2012, 07:10 AM   #12
Super Moderator
I have never seen a W204 without a TC drain. Only very early 722.9 transmissions fitted to the S Class before the W204 launch.
__________________
Old 09-29-2012, 07:03 PM   #13
Drives: '07 R320 CDI, '04 CLK 500
Glynn, I 'believe' I have the 722.9 transmission in my 2007 R W251. Does the 'reprogram' work on this transmission as I do with my 2004 W209 5-speed? (key to 'on', push throttle to floor, hold 5 seconds, turn off key, release throttle, wait 2 minutes before removing key) Works great in the 5 speed to get rid of 'granny' mentality!
Thanks! Jerry
__________________
R & CLK: AZN Optics 5000k LED running lights, CLK: Facelift LED taillights, Brabus Monoblock VI 18" staggered, Coco Mats, K&N, Resonator delete.. Stealth modding. . .
Jerryswfl is offline   Reply With Quote
Old 01-30-2013, 09:44 PM   #14
Drives: 2009 C300 Sports
Does RWD have to worry about this? Or this is just 4matic thingy?
snowmuch is offline   Reply With Quote
Old 02-02-2013, 05:25 PM   #15
Super Moderator
Updated step by step transmission service
__________________
Tags
200, 2001, 7229, 7g, 7gtronic, automatic, clk, fluid, flush, forums, mercedes, oil, speed, transmission, tronic
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
