Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-11-2012, 10:09 PM   #1
Drives: 2003 CLK500
Catalyc Converter replacement
My car has been making horrible rattling noise from the underside and it seems that my catalyc converter needs to be replaced.
I took the car to a dealer and an indy mercedes only shop and they tell me there's something inside the catalyc converter that either fell apart or something built up inside that is moving around when the car is running which is causing the terrible noise.
They also tell me that the car has 2 catalyc converters and both needs to be replaced together and with the way the clk's exhaust is designed, I need to replace pretty much the entire piping from the header down to the muffler along with the catalyc converter which sits in the middle of the piping.
I figure if I'm gonna dish out $1500 to replace the piping, I might as well do it with a good ones that can actually help with the performace of the car and also give me a little bit(literally, a bit more) of aggressive grumbling sound which I always thought my car needed.
I don't want those rowdy noise making devices.
There seems to be a discussion about straight pipes and whatnot but when I search for them I can't seem to find muc info on them.
Can I get some help as to where to look to find some aftermarket exhaust system for my clk500?
Any recommendation would be helpful too in terms of products and perhaps shops in Chicago area.
Thank you.
To remove this ad, register today or login if you already are registered!
nahugry is offline   Reply With Quote
Old 03-11-2012, 10:37 PM   #2
elijah's Avatar
Drives: W209 CLK 55 AMG
Cats: As you mentioned, you will need two. These are what most of us have.
http://www.ebay.com/itm/310311079252...84.m1423.l2649
As for exhaust setups, you have too many options.
You could do straight pipes using either an x-pipe and/or a muffler (Borla or Magnaflow). Search for exhaust threads for more info and ideas)
A setup shouldnt run you 1500$.
Best of luck
__________________
elijah is offline   Reply With Quote
Old 03-11-2012, 10:50 PM   #3
Drives: clk550
Send a message via AIM to Fatz
There are some real heavy weights on the forum who can help you. I am about to replace my resonator with a magnaflow x-pipe and y-pipe. Will insert them between the secondary cats and the beginning of the 2.75" pipe to the muffler. Good luck.
Fatz is offline   Reply With Quote
Old 03-11-2012, 11:11 PM   #4
kbahl21's Avatar
Drives: CLK 550
im ripping mine out on tuesday!
__________________
my build thread: http://mbworld.org/forums/clk-class-...ld-thread.html
kbahl21 is offline   Reply With Quote
Old 03-12-2012, 04:14 AM   #5
Kevwood's Avatar
Drives: '05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
I run 100 cell metal core primaries, no secondaries. Mine were brought in through Fox Germany.
__________________
KLEEMANN<
Kleemann supercharger, cams, headers & tune | H&R springs & sways | Koni suspension
Brembo GT BBK, 6/4 pot, floating composite rotors | GPT pulley | Magnecor KV85 wires
Carbon fiber; vented hood, Vorsteiner spoiler, diffuser, front lip and custom side vents
Quaife LSD | Magnaflow quad exhaust w/ 100 cell cats | E55K airbox w/ kevlar tubes
AMG Black Series strut bars | 360 Forged wheels, carbon fiber | eXce1on AV system
Mods/build thread
Kevwood is offline   Reply With Quote
Old 03-12-2012, 08:38 AM   #6
Drives: 2003 CLK500
Thanks for the help.
Now if I used the cats elijah has mentioned, it fits as a part of the whole straight piping right? There woudnlt be a way to simply replace the current cats with the new ones without replacing the pipe from what I gather?
Also, forgive me for my ignorance on the topic but do I just go to any muffler shops and ask for a staright piping? Who does these types of work?
Do I need to order all of the parts and ask the shop to install them? If so, where can i find thse packages? Oh and jus one more thing, where does a resonator fit into the whole picture?
Thanks in advance for your help.
Tags
500, cat, catalyc, catalytic, clk, clk500, concerter, converter, exhaust, noise, rattle, rattling, replace, replacement, w209
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
