Sign in using an external account
| CLK-Class (W209) 2003 on: CLK 270 CDI, CLK 200K, CLK 200 CGI, CLK 240, CLK 320, CLK 350, CLK 500, CLK 550 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: clk 350, Maserati GT, Porsche Cayman
Balance shaft concern.....
#2 |
Drives: 2007 CLK550 CAB, 2009 E350, 2000 Jeep Grand Cherokee
You will need to find out the serial # for you engine then see if it falls within the numbers.
M272 engines (bearing serial numbers up to 2729..30 468993) Here is a full link to some info. http://classactionlawsuitsinthenews....-m273-engines/ |
#3 |
55k in... and no issues with my 06'. Hate hearing your is such a mess. Good luck with it.
__________________
Mike
#4 |
Thank so much for the replies. If only MB was as great as the owners on theis forum we would have no issues!
The lawsuit link doesnt list the CLK350 at all, yet I understand the engine in question was used in the CLK 350. I found where one sees the engine ID#, but not sure if you can see that area from the engine bay. Is there a way on the MB site to enter the VIN and get the build data? |
#5 |
You can call a MB service talk to a SA and give them your Vin the should be able to tell you the engine #.
#6 |
Great...I'm on it!
#7 |
Exactly what I did while in the dealership....
__________________
Mike
#8 |
Okay....Eric at MBUSA was great. My engine serial# is 27296030 202025 and the MB TSB states "
M272 Engine Up to Serial No. 2729..30 468993 With the elipsis in there, I assume that the last 6 digits are the critical ones? The 08 CLK350 I'm looking at to swap, has serial # 27296030 661785 which looks outside the range. Any advice if I'm reading this right? Finally, does the 2008 CLK350 have the 7 speed tranny woes??? |
#9 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
No!
__________________
![]() Llandudno, Cape Town, South Africa |
#10 |
Thanks Glyn and everyone! Will be paying a bit more $$ and trading the 06 for the 08.
BTW, the rep at MBUSA told me the specific VIN of my 2006 didn't have the sproket potential, BUT the TSB lists my known engine serial# as part of the problem ones. Am I to assume that MBUSA doesn't acknowedge this issue enough to specifically include my VIN, or do they wait until the symptom sequence comes into the shop, then pull the TSB and see if the engine is on the problem list? Just wondering... |
#11 |
Forgive my rudeness as well Mike and Louie.....those are both beautiful cars!
#12 |
MBworld Guru
Drives: Current: 2002 C240, 2007 CLK550 Cabriolet, Previos: W163 ML320, W123 300D
The latter - they won't acknowledge that TSB until you experience problems. If you have then early enough, they might cover the repairs. The did for my 2007 with 35K miles, but others with over 90K miles said they were denied help.
__________________
-- - RODNEY |
#13 |
No harm.
__________________
Mike
#14 |
Does anyone know why isn't the CLK350 on the class action list if those engines were used in them? http://bit.ly/MgDKtz
#15 | |
Quote:
__________________
Mike
#16 |
MBworld Guru
FYI, the class action suit was crap. The lawyers that researched the problem were idiots and had some wrong models included, and others left off. Models don't matter. All that matters is if you have an M272 V6 or M273 V8 within the affected serial number range.
__________________
-- - RODNEY |
| Tags |
| 2008, 350, balance, big, check, climate, clk, clk350, concern, control, issues, m272, mercedes, problem, problems, shaft |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
