Sign in using an external account
| CLK-Class (W209) 2003 on: CLK 270 CDI, CLK 200K, CLK 200 CGI, CLK 240, CLK 320, CLK 350, CLK 500, CLK 550 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#26 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
__________________
![]() Llandudno, Cape Town, South Africa |
#27 |
You can see the difference in the picture above of the bolts. One is round (ball seat) the other is tapered (conical seat)
Look at your wheel lug hole and see which you have.
__________________
Mike
#28 |
Drives: Yo Momma
When i bought those shorter lugs for these wheels, i bought 4 extra just to be safe for future. I have those 4 in the car. I will take them out and take a picture and post it here in a few mins. Thanks again guys.
#29 |
Drives: Yo Momma
Here are some pics of the "bolt" "lug" "nut" whatever you wanna call it.
#30 |
Drives: 2006 Facelift CLK500 Cab-
Can you get a pic of the hole in the rim that bolt goes into as well?
__________________
97-jeep tj------06-CLk500 Cabriolet
#31 |
Drives: Yo Momma
Yeah ofcourse, but the wheels are mounted on the car? Will that make a difference?
#32 | |
Drives: Slk55, Clk500 Cab., C350, Civic
Quote:
I think He want to see if the wheel hole bolt is "tapered" or "ball" seat type.
__________________
#33 |
Just take "1" lug bolt out, and take a picture "down in the hole"....
__________________
Mike
#34 |
Super Moderator
You have tapered/conical bolts. Now see whether you have tapered conical seats or ball head seats on the wheel.
__________________
#35 |
Drives: Yo Momma
Here are some more pics.
#36 |
Drives: Yo Momma
ok thats gonna be a mission now lol i will try to take out one lug out and take a pic of that hole. I hope that pic shows what you guys are trying to see.
Again, appreciate all the input |
#37 |
Yep, that's what I was getting at, does the bolt "set" in there like they were built for each other or not
__________________
#38 |
Super Moderator
__________________
#39 |
Drives: Yo Momma
Glyn, thank you for the images.
#40 |
Former Vendor of MBWorld
If you need to get a cone seat lug bolt we have them in stock. If you have a vibration at 60 that goes away around 10 MPH later it is most likely a wheel balance problem. Factory Mercedes wheels are ball seat and most aftermarket wheels are conical seat. If you have any questions please feel free to give me a call at (516) 870-0351 and ask for Craig.
#41 |
Drives: Yo Momma
Thank you Craig, will do.
And guys, i will try to take one lug out and take a picture, i am sorry i have been busy at work. |
#42 |
Drives: Yo Momma
Hey guys, just to update you all.
I went to the dealer because i noticed my alignment was off. They fixed my alignment and while i was there i told them if they can look at my wheels and see if everything is ok and if the lugs were ok and what not. And they said yeah everything looks fine and lugs are ok too. So i guess these lugs are fine? And Craig, i might stop by you guys this saturday. |
#43 |
Super Moderator
Try to get a really decent balancing job done.
__________________
#44 |
MBworld Guru
Drives: Current: 2002 C240, 2007 CLK550 Cabriolet, Previos: W163 ML320, W123 300D
Good idea. I had a lot of issues on my W163 like this and it was tire balancing. Find a shop that has a Hunter 9000 and does road-force balances. Sometimes, both the rim and tire are out of balance, but not on the same radial direction. A good sign of this is a wheel with two balance weights on it. What the shop has to do, and the Hunter 9000 can tell them how, is dismount the tire and rotate it along the rim to line-up the heavy spots so only one weight will be needed.
__________________
-- - RODNEY |
#45 |
Drives: Yo Momma
You guys are amazing. Will do
#46 | |
Super Moderator
Quote:
__________________
#47 |
MBworld Guru
My W163 ML320 with mundane 16 inch rims had to have this. I had new tires put on at NTB and when I drove off, it was shaking like crazy, I took it back three times until someone on the ML forum recommended seeking out a Hunter 9000. My local MBZ indy had one and when they got through, it rode smoother than when fresh off the factory floor (and I know, as I was the one who drive it off the factory floor!)
__________________
-- - RODNEY |
| Tags |
| 500, alignment, centric, changed, clk, hub, plastic, rims, rings, shakes, steering, torquing, w209, weeks, wheel, wheels |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
