Sign in using an external account
| CLK-Class (W209) 2003 on: CLK 270 CDI, CLK 200K, CLK 200 CGI, CLK 240, CLK 320, CLK 350, CLK 500, CLK 550 [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2004 CLK500 Cabriolet Designo
2004 CLK Convertible Roof Rattle
#2 |
MBworld Guru
Drives: Current: 2002 C240, 2007 CLK550 Cabriolet, Previos: W163 ML320, W123 300D
Most cabriolet top noises can be solved by using the proper cleaner and lubricant on the seals. If it's an actual metal or plastic rattle, you may have a broken tie down on a hydraulic line. Open the top halfway and then look between the layers, comparing right side to left side to see if you can find it.
__________________
-- - RODNEY |
#3 |
Drives: 2005 CLK 500 Cab.
Hey Mike,
my 05 rattles like crazy in the winter time. Just lube it up and the noise is gone ( for a while )... I wouldn't use WD40 though
__________________
#4 |
MBworld Guru
Lubricating the rubber seals will solve squeaking noises, but rattles are usually broken cable ties on the top's mechanical and hydraulic control lines. As for lubricating the rubber, go ahead and get the "real" stuff from the dealer. It's not cheap, but it's amazing stuff and a bottle will last for years.
__________________
-- - RODNEY |
| Tags |
| 2004, cabrio, clk, convertible, forum, lubricate, mercedes, noise, parts, problem, rattling, roof, rubber, seals, wd40 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
