Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CLK-Class (W209)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-08-2012, 10:01 PM   #1
Drives: 03 CLK500
grinding from rear
hi guys i got a 03 clk500 with the 18in amg rims this weekend i hit a pot hole at a good speed showing off for some girls leaving a party cracked a rim and bent another the tire shop guy was kind enough to give me 17in mercedes loaners they didnt work drove the care less then a foot heard grinding and took tires off my rims are now fixed and on the car but now i hear a grinding/rubbing noise from the rear driver side tire any idea whats going on? which i could give more details the cars going into the shop thursday fix what ever it is driver side tie rod end and new front rotors
To remove this ad, register today or login if you already are registered!
Bi66s is offline   Reply With Quote
Old 05-08-2012, 11:17 PM   #2
MBworld Guru
Rudeney's Avatar
Drives: Current: 2002 C240, 2007 CLK550 Cabriolet, Previos: W163 ML320, W123 300D
Wow, you really got my attention with the thread title! But seriously, is the grinding noise present only when the tire is rotating? And is it always present when the tire is rotating? If so, it's likely not the suspension, but rather something in the brakes or the wheel bearing.
__________________
- RODNEY
Rudeney is offline   Reply With Quote
Old 05-08-2012, 11:54 PM   #3
Drives: 03 CLK500
lol thanks its only sometimes present only when wheel is rotating
Old 05-09-2012, 10:38 AM   #4
Drives: 05 CLK55 AMG
Usually caused by using lugs that are too long for the new rim to seat in correctly.
They'll tighten in too far and hit the ebrake calipers.
If its still making the noise with the old rims back on something is probably broke.
[edit]
Here ya go. Reusing old lug on new rim allows it to screw too far in, hitting the rear e-brake shoe:
Click the image to open in full size.
ambit is offline   Reply With Quote
Old 05-09-2012, 06:08 PM   #5
Drives: 03 CLK500
turns out it is the drive shaft that is going bad anybody know about how much to fix this and somewhere to get this part for a good price thankyou would appreciate a response asap
Old 05-09-2012, 06:13 PM   #6
Super Moderator
Glyn M Ruck's Avatar
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
OK you have likely damaged a CV joint on the drive/side shaft - replace the wheel bearing at the same time & check the parking brake mechanism.
If it's the propshaft that is making the noise then it's likely the rear flex disc.
__________________
Llandudno, Cape Town, South Africa
Glyn M Ruck is offline   Reply With Quote
Old 05-09-2012, 11:29 PM   #7
goddamnittttt
Glyn beats me again
Tags
500, back, brake, broken, clk, clk500, damaged, disc, flex, grinding, hear, lugs, mercedes, noise, parking, rear, started
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
