Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 08-26-2014, 04:44 PM
  #776
danvprod's Avatar
2008 C300 4Matic
OK.
Old 08-26-2014, 05:09 PM
  #777
Callam's Avatar
1993 E320 Coupe
Hi Can someone please tell me if the following is affected? Thank you!
WDB2110562A926550
Old 08-26-2014, 06:09 PM
  #778
seanay12's Avatar
2007 C230
Mine is WDBRF52H07F839416 and thank you in advance.
Old 08-26-2014, 09:37 PM
  #779
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by danvprod
Can you please check mine: WDDGF81X78F130122. Much appreciated.
MY2008's are not affected (and thus no W204 would be affected). You have M272 engine #883849.
Old 08-26-2014, 09:39 PM
  #780
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDB2110562A926550
You have M272 engine #281707, which is in the range for potential balance shaft failure.
Old 08-26-2014, 09:40 PM
  #781
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
You have M272 engine #394572 - it's in the range for potential balance shaft failure.
Old 08-28-2014, 08:55 PM
  #782
kennywong1234's Avatar
W209
Hi Rodney, pls help to check does my engine affected?
WDB2093652F109495
Thanks in advance
Old 08-28-2014, 10:51 PM
  #783
seanay12's Avatar
2007 C230
Sorry but can you check one more please, is there a link to check ourselves?
VIn is WDBUF70J75A685017 E500
Old 08-29-2014, 11:31 AM
  #784
jrogers1878's Avatar
2004 clk500
And yet another to check for balance shaft issue range and tranny problems:
WDBTK76GX6T066386
Thanks!!
Old 08-29-2014, 11:40 PM
  #785
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDB2093652F109495
Thanks in advance
That's a CLK320 with an M112 engine - no balance shaft worries there. It's the "350" and "550" engines that are the issue.
Old 08-29-2014, 11:42 PM
  #786
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
That's a MY2005 E500 with the M113 engine - no problems with those.
Old 08-29-2014, 11:43 PM
  #787
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
WDBTK76GX6T066386
Thanks!!
The CLK55 has an M113 engine - no balance shaft worries on that. And you have the AMG-modified 722.6 transmission - no particular issues with it, either.
Old 08-30-2014, 10:59 AM
  #788
W209
Thanks Rudeney!!
Old 08-30-2014, 03:11 PM
  #789
davidnz2003's Avatar
2006 clk350
Trouble checking engine number
Hi I was hoping to get your help with the same regarding my clk350 2006 however my vin keeps coming back as incorrect
wdbz093562f177938
please let me know if it is the problem engine
many thanks\dave
no its
WDB2093562F177938
Old 08-30-2014, 04:47 PM
  #790
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
wdbz093562f177938
many thanks\dave
no its
WDB2093562F177938
It's a MY2006 - it's in the range for potential balance shaft failure. All M272 and M273 engines through mid-production of MY2007 will be. Yours is M272 #170024.
Old 08-30-2014, 09:57 PM
  #791
BillyGV's Avatar
c280
Can someone assist me with the balance shaft failure info - 2007 MB C280 - Miles - 37,800 - VIN WDBRF54H17F853807
Old 08-31-2014, 12:15 PM
  #792
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
You have M272 engine #422567, which is in the range for potential balance shaft failure.
Old 08-31-2014, 02:02 PM
  #793
BillyGV's Avatar
c280
Thank you Rodney - I appreciate your assistance and knowledge
Old 08-31-2014, 02:33 PM
  #794
benzjam's Avatar
r350
am iI potentially in the range of this balance shaft problem
could someone check my vin 4JGCB65E47A050981 for the same issues please
thank you
Old 08-31-2014, 11:36 PM
  #795
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
thank you
Your R350's M272 engine is #515674 - beyond the problem range.
Old 09-02-2014, 10:28 AM
  #796
E350JR1710's Avatar
2007 E350 Sport 4Matic
Can someone assist me with the balance shaft failure info - 2007 MB E350 4matic - Miles - 70,xxx- VIN WDBUF87X27X214330
Old 09-02-2014, 09:18 PM
  #797
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
M272 engine #440489, which is in the range for potential failure.
Old 09-03-2014, 01:07 AM
  #798
ramsu's Avatar
E350
Hi Rudeney,
Could you please check vin # WDBUF56X77B039621 if this is within range? Couple of months back I had CEL and the code was 0276. Dealer said continuous adjustment of left intake camshaft stored - recommend replacing cam magnet. He said he cleared the error (no light) during 60k service (not fixed, just cleared). The light came back yesterday. I don't know if it is same issue.
Any help on how to proceed is appreciated.
Thank you for your help.
Ram
Old 09-03-2014, 09:54 AM
  #799
lust111's Avatar
MB ML350 BMW 325ci BMW 325xi
Could someone please check my vin for the balance shaft issue(2007 ML350)? 4JGBB86E67A152756
Old 09-03-2014, 10:53 PM
  #800
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by ramsu
Hi Rudeney,
Ram
You have M272 engine #459753, which is in the range for both Scenario 1 (balance shaft failure) and Scenario 2 (camshaft sensor magnet failure). Check the codes - P0016/P0017 (DTCs 1208/1200) are balance shaft failure. 0276 is cam magnet failure, which is an easy and inexpensive (even DIY) repair.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
