Please check my VIN for Balance shaft issue?
#801
MBworld Guru
Could someone please check my vin for the balance shaft issue(2007 ML350)? 4JGBB86E67A152756
#802
You have M272 engine #459753, which is in the range for both Scenario 1 (balance shaft failure) and Scenario 2 (camshaft sensor magnet failure). Check the codes - P0016/P0017 (DTCs 1208/1200) are balance shaft failure. 0276 is cam magnet failure, which is an easy and inexpensive (even DIY) repair.
Thank you Rudney. I checked the code today and it shows as P0022. After I removed the dirt around the magnets, CEL is off or number of engine start/stop made it go away. I am taking it to dealer this weekend.
Ram.
#803
MBworld Guru
P0022 = DTC 0276, which is a camshaft sensor magnet failure. You need to replace them. All four are about $100 and if you can, say, change spark plugs yourself, you can change these.
#805
Ram.
#806
Can anyone check WDBUF56X48B228843 for balance shaft range
Please someone check my 2008 e350 WDBUF56X48B228843 for balance shaft affected engine numbers.
#807
[QUOTE=Rudeney;5575218]4JGCB65EX8A072369 has M272 engine #769342, which is beyond the range for balance shaft problems (and also beyond the range for cam sensor magnet problems).
I can't figure out if my engine is included in the range - 272 960 30 513336?
#808
#809
MBworld Guru
#810
MBworld Guru
#811
MBworld Guru
#815
MBworld Guru
#818
2000 E430
Looking to buy a use 2008 e350 wagon, and fortunately did some research and found about about this common issue with the m272 engine.
Would you be so kind to check WDBUH87X08B320896?
Thank you,
Thank you,
#819
MBworld Guru
No worries with a MY2008. MY2007 is the only ones we need to check - any M272/M273 up through MY2006 will be "in the affected range", and MY2008 or later is fine. The first half ot eh MY2007 builds re in the range, but the last half are not.
Just to make sure, that VIN has M2723 #918432, which is well beyond the range.
#820
Can someone give an answer if my clk 350 with vin# WDBTK56G26T070162 belongs to the balance shaft problem?
At this time I already experiencing a problem with the transmission.
#821
MBworld Guru
#822
Thanks for the response and yes it goes on to a limp mode. It has 65k miles and I never had a transmission service. It was suggested to me to start by doing this first and will take it from there. It will be done today!
#823
MBworld Guru
Do you often hear clicking noises after shifting into D or R? If so, it's the turbine speed sensor. But if you have never had the fluid and filter changed, you should do that, as it is prescribed at 39K miles. Then again, if you have the speed sensor fixed, fluid and filter will get changed.
Oh, and maybe we need to create a new thread for this since it's not related to the balance shaft issue.
#824
hi rodney
can u just check this win plz i m looking to buy this car but wana know it s safe or no about balance shift problem---------WDBRF52H46F747238---2006 C230 THANK YOU SO MUCH.
#825
MBworld Guru
All MY2006 V6 and V8 MBZ's (except AMGs and "500" models which used the older M113 engine) will be in the range for potential balance shaft failure. Including this one. The only time you need a VIN check is with MY2007 - the problem was identified and resolved halfway through production of that model year.
