Please check my VIN for Balance shaft issue?
#826
#827
#829
MBworld Guru
#830
MBworld Guru
#831
MY2006 ML? Yes, it's in the range for potential balance shaft failure. All MY2006 xx230, xx280, xx300,xx350, xx450 and xx550 vehicles will be. MY2007 is when it was fixed - that's the only year where there is a question that needs a VIN look-up for the engine serial number to know for sure.
My check engine light came on and has the code P0016/P0017
I have a appointment with MB Oct 10 just wondering if it's save to drive the car until then ?
Thanks in advance
#833
MBworld Guru
#834
MBworld Guru
That's pretty much going to be balance shaft failure. Yes, it is safe to drive. In fact, you could probably drive it tens of thousands of miles like that before you have any serious problems. The variable valve timing system can compensate for the slack in the chain caused by the worn idler sprocket. Eventually, the sprocket will wear to the point that the balance shaft stops rotating, and that will cause additional engine vibrations. After that, it's just a matter of time before the timing chain really digs into what's left of the sprocket, which can cause issues with the chain itself. But again, that takes quite a while to happen.
#835
#836
1 Post
2002 SLK 320, 2004 SL 500, 2004 SL600
Hey Rodney
Would love a vin check when you get time!
WDBWK54F66F113357
Thanks for all the help you have given!
WDBWK54F66F113357
#838
MBworld Guru
#839
MBworld Guru
Hey Rodney
WDBWK54F66F113357
WDBWK54F66F113357
That's a MY2006 SLK - so yes, it will be in the range for potential balance shaft failure (as will all MY2006 V6's).
#840
Hi Rodney
Can I ask you to decode this VIN so I can see if this car has the troubled balancing shaft. It's a 2007 C280.
WDBRF54H17F932605
Guy
WDBRF54H17F932605
Guy
#841
Hi there,
I am a new member and am interested in buying a used 2007 C280 4MATIC. I am obviously concerned about this balance shaft issue and will probably not buy the car if it is affected.
I was wondering if someon could lookup the engine serial for VIN #: WDBRF92H47F931927 to see if it is affected?
Thank you so much! This post has been amazingly helpful and I really appreciate everyone's help!
#842
MBworld Guru
Hi there,
#843
MBworld Guru
Hi Rodney
WDBRF54H17F932605
Guy
WDBRF54H17F932605
Guy
#844
Could you tell me if WDBTK72F77T082835 is in the range for balance shaft issues? Thank you.
#845
MBworld Guru
#846
Can you please check this Vin number ?
I recently bought a 2006 c230 with 65k miles on it. Then I read about the Balance shaft issue. Can you please check if the following Vin# is an affected one.
Vin# WDBRF52H66A902692
Further, my dealer is offering third party extended warranty through firm called
"The Mechanic". They do mention Balance shaft in their engine repair thing. He is quoting 3K for 4yrs/50K miles.
Please advise.
Thanks a lot!
Kamal
Please advise.
Thanks a lot!
Kamal
#847
MBworld Guru
All MY2006 V6 engines will be in the range for potential balance shaft failure. If you are not in a situation where you can DIY your own repairs, then an extended warranty might make sense. And if the balance shaft does fail, it will cost more than $3k to fix. i would look for a warranty that also covers things in addition to the drivetrain, like alternators, AC system, window regulators, door locks, etc.
#848
BMW 328xi, E39 M5, and 07 C280
Hello Rodney,
New here and potential 07 C280 owner. Can you please check my vin #? WDBRF92H87F914077. Engine number which I think/hope is clear: 272 94130568902
Matt
Matt
#850
mercedes 2007 wdbrf92h67f929693
