Please check my VIN for Balance shaft issue?
#976
#977
MBworld Guru
Hello I thank you for your dedication to those who are in need of information like this.
I have a 2007 MB C230, I dont have the particular P codes 16 and 17 however I am still concerned and would appreciate if you can tell me if this vin fall within the range of possible balance shaft issue.....
VIN:WDBRF52H67F935003
And again its very wonderful that your helping in the way you are.
#979
#980
MBworld Guru
M272 engine #457374 - it's in the range for potential balance shaft failure.
#981
2007 e550
I have a 2007 e550 with 115k miles. Vin is WDBUF72X07B056522. Is this in the affected range? Appreciate any insight. Love the car, hate all maintenance costs.
#982
MBworld Guru
#983
Morning Mr Rodney,
Would you mind checking my 2008 e350? The VIN is WDBUF56X38B252096 and it has 135k miles on it.
Thank you.
Thank you.
#984
MBworld Guru
Morning Mr Rodney,
Thank you.
Thank you.
#985
2008 ML350 & 2008 CLK350 Convertible
Balance shaft issues
I purchased a 2008 ml350 and a 2008 clk350 from a non mb dealer. The day after I drove home with the ml my cel came on ran rough for about an hour or so and then ran fine the rest of the day. I called my salesmen and he had me bring the car in to their shop. Manager said I had a balance shaft issue and they were going to take care of it, they even rented a car for me, they said they would need the car for about a week. He calls me the next day and says he saw an updated bulletin and said my car was fine. This is making me very nervous since I have an 1800mi road trip coming up next month.
After doing some reasearch on this I came asross this forum and I appreciate all the help I can get.
My question is I looked up my eng # on both of my vehicals and the ml falls into senerio#2 and the clk falls under seniaro#3. I was wondering if I need to be wooried about this problem on both of my vehicals.
Thanks in advance for the help!!!!!
#986
Also I forgot,
I have 113,000mi on the ML350 which has vin# 4JGBB86E28A331667
and the CLK has 48,000mi with vin# WDBTK56F48F250297
Thanks again
Thanks again
#987
MBworld Guru
Also I forgot,
Thanks again
Thanks again
Your CLK350 has M272 engine #867303.
Neither of your cars have engines in the range for balance shaft failure. My guess is that the dealer you purchased from is just confused with the different scenarios covered in the TSB. Here is a copy of it:
http://benzbits.com/BalanceShaftTSB.pdf
Actual balance shaft failure is scenario #1 and that is a very expensive repair as it requires removing the engine. As you can see from comparing your engine serial numbers, neither of yours fall into this range. This is expected to be the case with MY2008 vehicles as the problem was discovered and rectified before those were built.
The other two scenarios are problems with the camshaft solenoid adjusters, which are just electromagnets bolted on the fronts of the engine heads. They are used to activate the camshaft adjusters for the variable valve timing system. In Scenario #2 (Which your ML350 engine calls under), the magnets are defective and need to be replaced. Although you may only see error codes on one or two of them, I'd replace them all. All four can be bought for about $100 total on parts.com and it's a fairly easy DIY, or maybe a couple of hours of professional labor.
Scenario #3 is just an oil leak (usually no error codes are present). Both of your cars fall under this. The repair is to replace the seals on either the solenoids or the position sensors. Worst case is to replace the solenoids if they are leaking internally. Again, an easy and fairly inexpensive repair.
I guess the real solution here is to get the codes that activated the MIL. They may or may not have anything to do with these issues.
#988
McLaren Mp4-12C, 2012, Jaguar Sovereign 1996, BMW M5 1986 Sover
Hi Rodney
I look to buy a first reg april 2008 280 clk with vin number
WDB2094541F257133.
I suppose the chances are pretty good, but it would be great to have this confirmed before putting down the money coming wednesday... It has 85k on the meter and is otherwise in impeccabel condition.
Great thanks in beforehand if you could check this one as well:_)
WDB2094541F257133.
#990
Hey Redbaron if you go through this thread someone had a russian site you can run your vin through and get your eng serial # then there is another post thst has the range of eng#'s that have the balance shaft issues hope this helps
#991
MBworld Guru
Hi Rodney
WDB2094541F257133.
WDB2094541F257133.
#992
Please check my VIN# for the balance shaft issue
Hello,
I currently have a 2007 C280 4Matic and would like to find out if my VIN# (engine serial #) is one that is in the range or a good one. Thank you. The VIN# is WDBRF92H57F908804.
#993
It great that other people can check to see if your car if impacted by these issues but you can do this yourself.
1. Go to www.MercedesMedic.com/decode
2. Use Option 1 to decode your VIN.
3. You will get your engine serial code. Compare it to these numbers. If you are higher than these numbers you are fine.
Affected Engines Serial Numbers
M272 Engine Up to Serial No. 2729..30 468993
M273 Engine Up to Serial No. 2739..30 088611
You can read more here:
http://www.mercedesmedic.com/check-m...y-vin-m272273/
#994
VIN / ENGINE NUMBER CHECK THAT WORKS:-)
Great Tepelena. I tried the russian site mentioned earlier in the tread, but it did not work, even with a russian speaking friend by my side.
BUT, this latest site as mentioned above worked instantly, giving out engine number plus other specs. www.MercedesMedic.com/decode
Time to say a great thanks to Rodney for his efforts and hereafter check by ourselfes!
#996
Hey Rodney could you look up the vin code WDDNG71X57A118089 for me? I'm trying to buy another car and I don't want that balance shaft issue again. Ever.
Thanks!
Thanks!
#997
MBworld Guru
Thanks!
Thanks!
#998
2006 CLK500, YUKON XL Quadrasteer, CRF 450x
#1000
4JGCB65E88A074489 has M272 engine #802251. As expected with a MY2008, it is beyond the range for balance shaft problems.
WDBTJ56H57F211219 has M272 engine #438007 which is withing the range for potential balance shaft failure.
Please, advice for VIN: WDBTJ56H77F223291 - is it beyond or within the range for potential balance shaft failure.
Thanks, Alex
