Please check my VIN for Balance shaft issue?
#1176
MBworld Guru
WDBUH87XX7X220824 is actually a MY2007 - 10th digit of the VIN is the model year. But no worries, it has M272 engine #507077 which is beyond the balance shaft problem range.
#1177
W211 E55 AMG 2005 model
Check vin for harmonic balancer recall
Hello everyone, I own a 2005 w211 E55 Amg Mercedes and I have been told that I have to replace my harmonic balancer and I only have 72000 km . I have had the car serviced by only Mercedes dealership and I have had many problems with it. Now after reporting that I have a slight noise in one of my pullies after recently changing all of my pullies that my harmonic balancer needs replacing. I have been quoted something like $4200 for the job and I am not too happy about it. After looking on line I see that it is a common problem and say that my model may not be covered under the recall. But also saw that you can check via your VIN number of your vehicle and that some of my year are still covered according to the vin number. So if someone could please check for me my vin number it would be greatly appreciated and post the answer for me to see the outcome please.
My VIn number is
WDB 211076.2A.840743
My VIn number is
#1179
EML light turning on an off
A few days ago my engine light came on then turned off my E350 (W211) and when I got it checked by the mechanic, a P0012 stored fault came up; continuous camshaft adjustment (RIGHT): Incorrect position of intake camshaft (P0012).
So, I removed the four camshaft sensors and checked the position of the camshaft 'timing markings'. The left bank inlet and exhaust, and the right bank exhaust markings were centered but the Right bank inlet timing marking was slightly off centered, in comparison to the others but the full circle was still visible.
I'm not sure what this means, as you have already mentioned that this MB ( VIN: WDB2110562B100725 Engine number: 272 964 305 470 57) is out of the problem range , so do you have any ideas on what this could mean?
I would greatly appreciate some help on this problem. I've only driven about 95,000 km and am worried.
Thank you,
#1180
MBworld Guru
It's out of the range for balance shaft problems. P0012 (DTC 0272) is a symptom of camshaft solenoid (cam magnet) failure, covered under "Scenario 2" of the TSB. And your engine is still in range for that. Here in the US, all four solenoids can be bought for about $100 at discount, and as you have found, thye are fairly easy to remove and replace.
http://benzbits.com/BalanceShaftTSB.pdf
#1181
2007 C230
Can anyone tell me how I file a claim? I will be doing repairs in about two weeks. My dealer wants around 7k and an independent shop that does mercedes benz wants 3.5k. The car is a 2007 c230 and has 57k miles, it's within the affected range of the engines with the balance shaft issue. So because it has between 50k and 70k miles they will cover 70%, correct?
According to the FAQ on balanceshaftsettlement.com if I go to an independent shop they will refund up to 4k. Did I read that correctly? Meaning my $3.5k repair will be covered by MB?
Once I get the receipt from the repair shop, do I submit that copy of the receipt with the claim to Mercedes? Also, how long do I have to file a claim? Is there a deadline?
If the repair submitted for reimbursement was performed at an Independent Service Provider (i.e. a non-Authorized Mercedes-Benz Dealer), the "reasonable repair amount" will be the lesser of the actual amount charged or $4,000.
#1183
2009 ML350 4Matic
Hey guys! My 2009 ML350 4Matic w/ ~80k miles just had P0016 and P0017 come on. Dealer says it just needs a timing chain (it's under warranty thankfully). They claim it's not balance shaft related.
Can you tell me if I'm within the affected range? VIN: 4JGBB86E59A476199
Thank you for any help in advance!!!
#1185
2007 C230
Just got this from them:
I'm still not sure if they're hinting that the effective date is August 17th or that it's going to be late September.
The Court granted the Motion for Final Approval, approved the Settlement, and certified a Settlement Class on August 17, 2015. Therefore, all repairs must have been made prior to the Effective Date in order to be considered for reimbursement. However, the Effective date is currently on its way to being finalized and will posted on our website (estimated to be late September). Please check back within the next two weeks for an update, or you may visit the website periodically for any updates. We will post the Effective Date once we receive the information.
#1186
2007 C230
Quick reply by them
Good Morning,
To summarize things, you have two options. You can opt to have repairs performed prior to the Effective Date (which will be posted on our website late September) or you may wait until the Effective Date has occurred in order to begin your repair process directly with MBUSA. This option will not need a claim form to be submitted, as you begin the entire process with them.
The Effective Date refers to the first date by which any Final Order and Judgment entered pursuant to the Agreement becomes final. The Final Approval hearing was set for August 17, 2015; however the Court will also consider Objections received and may decide the issues at the Final Approval hearing but we do not know how long these decisions will take. Therefore, once the previously mentioned have been resolved, they move on to finalizing the Effective Date. (Again, estimated around late September).
Please read the following details regarding the Settlement in addition to the information you were previously provided.
If you get the repairs done after the Effective date we will not be notifying you regarding MBUSA’s process with the repairs as we only deal specifically with the Settlement. You will need to contact MBUSA directly to inquire of their process. This will not require you to submit a Claim Form since you are dealing directly with MBUSA. Repairs performed after the Effective Date must be performed at an Authorized Mercedes-Benz dealership. Please check the website within the next two weeks for an update, or you may visit the website periodically for any updates for the Effective Date posting as this will serve as an important guideline on when you should contact MBUSA to have repairs performed directly with them. Once the Effective Date has occurred, you may begin to contact MBUSA to inquire about the process with them.
However, if you opt to have repairs performed before the Effective date, and you submit a timely Claim Form along with your supporting documentation, if we require additional information we will contact you via mail. Please be advised that at this time we do not have an estimated distribution date. The review process will be in several phases; therefore will take some time. Once we begin our review process, if we require additional information from you, we will contact you. Please feel free to check our Settlement website periodically for any updates.
See FAQ #5 of our Settlement website for details regarding coverage. You will want to contact MBUSA directly to confirm their process as we do not have information nor authorization to speak on their behalf outside of the Settlement.
If you have any further questions or concerns, please don’t hesitate to contact us.
Best.
Seifi v. MBUSA Settlement Administrator
Best.
#1187
MBworld Guru
#1188
2009 ML350 4Matic
That's odd. This engine is well beyond the balance shaft trouble range. This is the first time I've heard of an M272 timing chain problem. A stretched chain would cause these same errors The good news is that timing chain replacement is not horrible - it can be done with one valve cover removed instead of pulling the whole engine out as with balance shaft repair.
#1190
Ok I see, thank you! Do you know any online dealers who sell the solenoids for these cars?
Thanks again,
#1191
MBworld Guru
The solenoids should be readily available at the parts counter of any authorized dealer. If you are int he USA, parts.com is a good source for discounted OEM parts shipped from their dealer network.
#1193
#1194
#1195
MBworld Guru
#1196
MBworld Guru
Yes, any MBZ with an M272 or M273 engine built prior to mid-model year 2007 will be in the range for potential balance shaft failure. This includes the xx230, xx280, xx300, xx350, xx450 and xx550 models.
#1199
MBworld Guru
The wife is looking at C-300 at MB OKC and before we drive down to OKC can you run the VIN?
WDDGF54X38R038482
Thanks much.
WDDGF54X38R038482
Thanks much.
#1200
