Please check my VIN for Balance shaft issue?
#1352
2006 clk350
Hi, I just bought 2006 clk350. The vin no is WDBTK56G36T057081.
I don't know the problem already occurred or not?
It is 104k now. Could you please check the engine falls in the affected range? Is there any way to know that it has been already taken care of? It is an AMG.
#1353
MBworld Guru
All MY2005 and MY2006 vehicles with the M272 V6 or M273 V8 will be in the range for potential balance shaft failure. Your CLK350 has the M272 so it's in the range. Regarding mileage, there are two schools of thought here. One is that the affected balance shafts will fail early and if you get over 100K miles, it's less likely that you have a bad one. The other is that all of the balance shafts were defective and will fail, just that some will fail earlier than others. Only MBZ and the supplier know for sure, and neither one is divulging that info. Anecdotally, it does seem that there were more reports of balance shaft failures in the forums with low-mileage cars as opposed to those over 100K.
#1356
MBworld Guru
MY2008 will be beyond the balance shaft problem range. Only MY2007 needs checking. Ay xx350/xx550 prior to MY2007 is in the range, after MY2007 is out of range. MY2007 is half/half.
caseybalbachan (12-30-2016)
#1357
Newby please help VIN Check for S550 Balance Shaft
I'm about to sink big money (to me) into a 44k mile 2007 S550 4matic and I'm just now learning of the balance shaft issue. I'd better slow my roll...
Can anybody help please with a VIN Check to get my engine # and see if this vehicle is affected?
WDDNG86X77A144174
You might be saving me $4-$6,000 so THANKS IN ADVANCE IF YOU CAN HELP!
WDDNG86X77A144174
#1359
MBworld Guru
WDDNG86X77A144174
WDDNG86X77A144174
#1360
2007 Mercedes E-350 4-Matic
re: 'Please check my VIN for Balance shaft issue?'
WDDNG86X77A144174
WDDNG86X77A144174
How much are you paying for this 2007 S550 4matic ?
I am a big fan of this particular model year and with such low mileage it must be in very good condition .
#1361
Could someone check my VIN for me? It's a 2007 CLK 550 WDBTJ72H47F213206
#1363
#1364
I have another potential one with good miles/price point so this is the deciding factor: WDBTJ75H86F179720 also how do you figure out whether or not it is within the range? I ask just so I won't have to post back here every time I find another potential buy.
EDIT: I see now since it's a 2006 it is in the range already, how likely is to have occurred around the 82k mile range? I'm trying to use my head over feels but it has the exterior and interior color I want!
#1365
I think the general consensus is two things: (1) that it happens to a fairly small number of cars in the affected range; and (2) if it is going to happen, it can happen at any miles.
My own view is that given how relatively inexpensive these cars are now, why even bother thinking of one in the affected range unless you have proof it was fixed already. If you are looking at high mileage cars to save money, then the price difference between one in and out of the the range is what - maybe $3,000? Not worth it to me. Plus you get a newer car.
#1366
#1368
#1369
#1370
MBworld Guru
#1371
MBworld Guru
WDBRF87H26F798618 - That's a MY2006 E350 - all MY2006 xx350's are "in the range" for balance shaft failure.
#1372
2011 GL 550, 2010 MB S550, 2004 BMW 645Cic 1988 Corvette
Please check this VIN# please. WDBTK72F29T105554
#1373
MBworld Guru
That's a MY2010 - no balance shaft worries. Only MY2007 needs to be checks - any M272/M273 engine before that will be in the range. MY2007 was half/half, by MY2008 it had been corrected.
#1374
Could you check this one for me please? WDBTK72F57T079304
Disregard this, found some other issues with this vehicle
#1375
clk350
I have a 2006 CLK350 that has been setting for about 9 months with various issues. I am trying to determine if it is worth repairing or part the car out.
Please check my VIN for Balance shaft issues.
VIN: WDBTJ56H56F182917
Thanks!
Thanks!
