Has anyone replaced the middle A/C vent plastic disc with wood?
Rating: Thread Rating: 3 votes, 5.00 average.
Old 04-22-2013, 09:03 AM
baybarda's Avatar
Mercedez-benz CLK 200 Kompressor
Originally Posted by California
If anyone wants my OEM gray vents and round plastic disc thingie, let me know. I slightly dinged the plastic "chrome" trim on the side of the vents and bought a new piece -- also my plastic disc is fine i used a credit card to take it off. You can buy that plastic chrome trim on ebay cheap for a perfection repair.
Im intrested on that part California do u have photos of that part ?
or e bay link?
Old 04-22-2013, 07:03 PM
California's Avatar
CLK350 '06
or e bay link?
I've got it in the box here:
For some reason cannot load the photos.
Which part do you need, the whole double vents and the disc or just the disc?
Old 04-08-2014, 10:15 AM
baybarda's Avatar
middle plastic part only
Old 04-15-2014, 02:25 PM
Timewarpone's Avatar
05 CLK320 Cabriolet W209 & 2011 BMW X3
Just curious but my chrome trim is flaking off my center vents. Looks ugly. Is there a repair for this or do I have to replace the whole center vents? (Which looks easy enough) I was thinking about nail polish? Any ideas or suggestions?
Old 04-15-2014, 11:44 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I have the same problem. If you find a good chrome nail polish that looks decent, let me know! The chrome trim ring on my cup holder is also flaking off. Good grief, it's 2014 - can;t someone come up with a decent chrome touch-up paint?
Old 04-16-2014, 12:50 AM
I agree!!
Old 04-17-2014, 10:40 AM
  #32
Out of curiosity I did a search on Ebay for chrome paint and chrome nail polish. I came up with 2 or 3 choices that should work for around $3.50 to $8.00
http://www.ebay.com/itm/301154538853...84.m1423.l2649
http://www.ebay.com/itm/370598566866...84.m1423.l2649
http://www.ebay.com/itm/350989117658...84.m1423.l2649
Old 04-17-2014, 08:09 PM
  #33
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Those won't be reflective like real chrome - they will be more like a slightly shiny gray. A paint-on reflective chrome finish seems to just not exist. I really wish some smart scientist would come up with some sort of molecular "nano technology" to make it happen.
Old 04-20-2014, 05:37 PM
  #34
California's Avatar
CLK350 '06
My piece is still in the box and I'll send it to anyone for shipping only -- so you can play around with it.
Old 05-07-2014, 02:18 PM
  #35
KingDuckett's Avatar
2005 CLK500
CF AC vent panel
I just popped the center panel and wrapped it in 3M 1080 Carbon Fiber this morning
Has anyone replaced the middle A/C vent plastic disc with wood?-img_20140507_084215_761.jpg
Has anyone replaced the middle A/C vent plastic disc with wood?-img_20140507_110027_482.jpg
Old 05-07-2014, 02:43 PM
  #36
Lovetoflyfish's Avatar
'08 CLK 550 Cabriolet, '15 ML 350
Looks Good
Attachment 286108
Attachment 286109
Thank you for the images and type of material used.
Can you add any additional notes or tips regarding the installation, please?
My first wonder is to your wrapping the whole piece and how well it seemed to fit back in place; especially with the areas that have the thicker chrome trim.
There is a nice company that has some very thick carbon fiber applique. It looks great (they sent me a small piece) but I worry about the fitting as well as when, in the summer months, it gets hot inside and wonder if the material migrates, peals, or bubbles?
How about cutting the pieces needed with enough extra length to wrap or for those areas that surround a switch or control?
Are you going to try this on the door molding?
Thanks, in advance, for any additional help and best regards, Evan
Old 05-07-2014, 03:02 PM
  #37
2005 CLK500
Because of the vent roller buttons, its going to be difficult if you dont have a X-acto knife to cut between the roller buttons. I found it easier to remove all the panels and wrap separately and theres a certain ways that you'll have apply your vinyl so your buttons fit properly without looking crapply. I wrapped everything with 3M 1080 Scotchprint Vinyl. As far the bubbling, the wrap itself has a sealing coat that helps reduce bubbling and i understand that the CLK turns into a mircowave on hot days but if wrap properly, there should be no problem. I cut 5in x 5in of the vinyl and just wrapped the whole thing ac vent panel. I honestly didnt want to deal with the chrome trim at this point (laziness) but the art is when you apply the vinyl plus with leaving a proper amount to heat and WRAP the panel. I left about Quarter inch all around the panel to stretch the vinyl. By doing that, its going to be perfect because you have to leave space for the "plastic connecting forks" to connect back in to the dash. I plan on eventually wrapping the entire car in CF
Old 05-07-2014, 03:38 PM
  #38
...I plan on eventually wrapping the entire car in CF
The entire car or just the trim?
Thanks for the quick reply and additional tips.
Best, Evan
Old 05-07-2014, 04:02 PM
  #39
2005 CLK500
Best, Evan
I plan on wrapping the tirm in the interior in CF and doing a full vinyl wrap on the outside of the car in CF.
Old 05-07-2014, 05:48 PM
  #40
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
dumb question
How do you decide what direction the twill is headed on the different pieces?
Old 05-07-2014, 06:23 PM
  #41
2005 CLK500
No, i thought of the same thing. For full car wraps, i normally if it was a gloss type of vinyl then i would believe that it really doesn't matter in the type of size that you buy in but because CF is a patterned type of vinyl then the installation would have to be done and applied by using one full roll across the car rather than panels and pieces.
Another way for money cost is to buy your vinyl thats equally sized in dimensions. So for example. Usually a cars fenders and doors are the same in height and different in length. For example, If my fenders on a clk-class are 3feet x 4feet and my doors are 3feet x 5 feet. My best choice would be to go 5ft x 5ft so i can easliy cover those panels and have enough vinyl to apply it so the direction look uninterrupted because when i bought it using this method, i bought enough to compensate and adjust my pattern so it will look even and correct
Old 05-07-2014, 06:29 PM
  #42
2005 CLK500
Even in this picture that i posted above, the direction is off. As far as your interior, installing the vinyl so the pattern stay straight come down to the installer.
Old 05-07-2014, 10:24 PM
  #43
pskdude's Avatar
2004 CLK500 - W209 - Cabrio
CF
Hey King, funny you posted these i was just about to wrap that middle portion with CF i was dying that it was scratched up from the previous owner. After seeing your wrap i would much rather have than the wooden trim. Now my only question would be my Steering wheel lmao. How the hell would i wrap that lol...
Old 05-07-2014, 11:22 PM
  #44
2005 CLK500
Steering Wheel
So i sit in my car, thinking the same thing, what the hell am i going to do about the steering wheel. You can technically wrap as it stands but seriously, it would be a waste of time and material. Now if theres a way to take apart the steering wheel then maybe we can see for a better solution. For a official look, (unless someone knows something or someone that is offering a carbon fiber steering wheel) the only option i know is purchase the very expensive amg steering wheel and install it from there.
-I was talking to my wife about this and i told her this, "everything within your car was pieced together, (the wood trim and leather, i dont believe is one piece on the steering wheel) with that being said, it must come apart in some way or fashion
Old 05-07-2014, 11:35 PM
  #45
2005 CLK500
Has anyone replaced the middle A/C vent plastic disc with wood?-steering_wheel_w219_1.jpg
http://www.mecdesign.de/new/en/tunin...ing_wheels.php
Something like this right?
Old 05-08-2014, 10:44 AM
  #46
pskdude's Avatar
nice
that looks sweet. I could imagine the cost of them nevertheless lol...I know some people dip parts in CF as well. I wonder if the trim comes off the steering wheel...
Old 05-08-2014, 01:46 PM
  #47
2005 CLK500
Yeah but looking at the steering wheel, its seems to be all stitched in together behind the steering wheel so of course, you "shouldnt" be able to take it apart. The fact that they are not cheap doesnt allow people to proplerly experiment with them as often either. All we need is one brave soul lol!!!!!!!!!!
Old 05-13-2014, 11:42 AM
  #48
MaconPerformanc's Avatar
2006 CLK500 vert
Originally Posted by Evileye
Purchased the 2009 CLK air vent panel piece from Mercedes to replace the sticky one that was on mine. I used a credit card to slide behind then a plastic spatula (George Foreman grill cleaner) to get behind that and pried it up and "pop" it came. The new one snapped in place no problem. Then I used mineral spirits to rub down the stickiness on the old one and it is now like new. Pictures attached.
Thanks for this... I used goo gone on mine and it looks and feels great, a little elbow grease is all it took.... Thanks evileye
Old 02-09-2016, 05:44 PM
  #49
lench10's Avatar
Mercedes Benz CLK350
Searching for middle air vent part
Where can I buy this part? Anyone with OEM part #?
Old 02-10-2016, 01:11 PM
  #50
eteller's Avatar
2009 CLK 350
Anyone have any pics of the wood one?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Has anyone replaced the middle A/C vent plastic disc with wood?
