Old 06-10-2015, 01:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How do I replace my serpentine belt?
Old 04-23-2013, 12:31 AM
klonsbury's Avatar
2007 CLK 550
I've searched and can't find the answer. In another forum, it mentions removing a bolt near the tensioner pulley and then the tension will actually move. Thus allowing the belt to come off. Is this correct?
Thanks!
Kyle.
Old 04-23-2013, 12:50 PM
quaalude's Avatar
2012 C63 Coupe P31
On the M113 V8, the tensioner has a 17mm bolt that you use to pivot the tensioner. Put a socket with breaker bar or socket, ratchet, and long pipe on the bolt and rotate the tensioner counter-clockwise and remove the belt. Everything can be done from up top. No need to remove any bolts, at least on the M113.
Old 04-23-2013, 02:43 PM
klonsbury's Avatar
2007 CLK 550
Thanks Quaalude! I'll try that out tonight.
Old 04-23-2013, 10:16 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I can usually replace it without any tools - just pull on the belt and the tensioner will give enough to slide it off the water pump pulley. Same with putting it back on - route it on everything but the water pump, then pull it onto the water pump.
Old 04-24-2013, 12:53 AM
klonsbury's Avatar
2007 CLK 550
Belt replaced!
Spark plugs are up next. Anyone know what gap is best?
Old 04-24-2013, 10:01 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
If you get the proper plugs (Bosch), they come pre-gapped (Oh and torque is 23Nm).
Old 04-25-2013, 12:37 PM
lars's Avatar
05 CLK 500 cab
Is there a recommended mileage interval for the belt replacement?
Old 04-25-2013, 10:30 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Just check the belt for cracks and wear at every service. Environmental factors will have a lot to do with its lifespan, but 100K miles is not unusual.
Old 04-26-2013, 12:01 PM
lars's Avatar
05 CLK 500 cab
Thanks!
Old 04-26-2013, 02:16 PM
bheng's Avatar
2003 CLK 320
does anyone know if this is the same on a m112? hopefully easier because I have more engine bay room =D?
Old 04-26-2013, 10:54 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Almost identical on the M112 - and yes, easier as there is more room to work.
Old 05-11-2013, 04:07 PM
Dimitri's Avatar
2014 E350 Coupe 4Matic
Im also need to change my belt, what is the OEM brand and part number for it? I have 2004 CLK500
Old 05-11-2013, 11:43 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I don't know who the OEM is, but the MBZ part number is A0159972592. Honestly I'd probably just buy a good quality aftermarket belt from a retail auto parts store - there's not a lot to belt technology.
Old 03-25-2016, 04:56 PM
faran's Avatar
2004 CLK 500 with AMG Package, Not Convertible
Sorry for bring this thread back from dead, but I am at ~78k miles and think on the original belt.
I don't see any cracks or anything but thinking to replace as a precautionary measure. Is it really that easy without opening that 17mm bolt? Should I also replace the tensioner too or just the belt? No noise or anything so far.
One more thing, is water pump right above crank pulley or?
Old 03-25-2016, 05:48 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
no real reason to replace it if there are no cracks but yes its that easy. I wouldn't replace the tensioner just to replace it
Old 03-25-2016, 06:21 PM
faran's Avatar
Thanks for your advice. I'll hold on to belt for sometime then. No tensioner for me, just the belt it is.
Thank you
Old 03-26-2016, 04:59 PM
clydem's Avatar
2005 320CLK Cab
My wife is cracking 100K and the belt looks fine.
Old 03-26-2016, 05:05 PM
faran's Avatar
Is it from 2004 or 2005 and an OE belt?
Old 03-26-2016, 05:15 PM
clydem's Avatar
2005 320CLK Cab
2005 & Original.
But if the belt gets replaced (thinking about it) so would the tensioners.
The only belt I've ever seen NEED replacing was my old '73 Pinto. It had a cut in it.
Old 03-26-2016, 05:22 PM
faran's Avatar
2005 & Original.
Makes sense, please do post here if you end up replacing tensioner and which ones would you replace? Just one or any other?
Old 03-26-2016, 07:28 PM
gixxerboy's Avatar
why would you have to replace the tensioner? its hydraulic so unless that part has failed or the bearing in the pulley itself there is no need. Rubber cracks with age, its a part that eventually you have to replace, the tension er may never need to be replaced.
Old 03-26-2016, 10:36 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The tensioner uses a spring - not hydraulics (though 4MATIC models do have an additional hydraulic strut in addition to the tensioner). The spring rarely fails, though I did have one do that on my C240. It's symptom was a "clucking" noise when the power steering pump was stressed by tight turns.
Typical problems of the tensioner and the idler pulleys are bearing failure. This will be a squeaking noise. When this happens, replace the pulley because it will eventually lock-up and destroy the belt. Another failure is if these plastic pulley crack. That can also shred the belt. That also happened on my C240 and the strips of belt got sucked into the alternator. It took me an hour to unwind all the crap.
When you have the belt off, inspect the idler and tensioner pulleys for any cracks. Rotate them to fell for bearing wear.
Old 03-27-2016, 07:58 AM
faran's Avatar
Thanks so much GB and R.
I am going to hold on to this belt for now and will look and keep an eye to see if it's falling apart, then will replace it.
When no belt would be there, will check for any abnormal noises on the tensioners too, as well as plastic pulleys.
Thank you again.
Old 03-27-2016, 09:15 PM
faran's Avatar
Thanks Rodney. Is it possible for you to share a picture of the pulley/tensioner which can fail or has a possibility of bearing failure? Is it the one with 17mm screw on it? Or the one on the front of the engine with a really long bolt?
So far there is no squeaking or any other noise, does it mean things are good for now?
Old 03-27-2016, 10:00 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Refer to this:
http://benzbits.com/M112/BeltRouting.pdf
#4 is the idler pulley. When you replace it, you just remove the Torx bolt and swap the pulley with integrated bearing. #7 is the tensioner pulley. It's replaced as an entire assembly.
Quick Reply: How do I replace my serpentine belt?
