Radio has no sound
Radio has no sound
Hi all hope someone has an easy (cheap) answer. My 2006 CLK350 radio was working fine and then today when I turned it on the display was working ok but no sound came out.(its not in mute mode). All buttons and displays work normally, CD's change normally but no sound in any mode????
Thnx
Thnx
I had a very similar issue on mine, everything looks like it should be working but no sound. I opened up the panel in the trunk...drivers side to check fuses, and there is a bank of connectors there and the one on top... green was loose. Easiest fix ever. Good luck
Found a fix for the radio problem. I pulled the radio fuse with key on/radio off then turned key off put fuse back in turned key on/radio on and all started working normally.
