Bi-xenon malfunction
1 Post
I drive the racism out of BadDebt. ;)
Hey guys, within the last two years I had to replace my OEM bi-xenon ballast 4 times.
Bulbs are all oem and work fine when switched with the drivers side.
Generally the ballasts last for about 3-4 months then dies out of nowhere.
Connections are all solid and harnesses look fine. I'm at a loss for options now and wonder if you guys had any insight on the core problem?
thanks
thanks
supafly, which ballasts are you buying? I bought mind from HIDextra...albeit about 4 years ago, and they lasted me a good 2 years before having to swap them out.
EDIT sorry I just read that they were OEM. can you use aftermarket ballasts and bulbs with OEM?
