coolant fan not running
2008 CLK 350. My coolant radiator fan is not turning at all. I purchased a used fan from a salvage that was guaranteed working and it does not work either. I used a volt meter at the connector for the fan and I get no voltage. I tried turning the A/C on because I've read the A/C always makes the fan run and that did not produce any voltage at the connector either.
Any ideas for testing procedures? The fan has 2 big wires and 2 small wires.
MBworld Guru
Check the fuse. It is actually #5 in the "pre-fuse" panel, which is located below the positive jump terminal on the right side of the engine:
http://benzbits.com/w203/PreFuse.pdf
MBworld Guru
It's a standard bolt-down 125 amp "mega" fuse. It should look like this:
You should be able to get it at any auto parts store.
Now, the question will be, why did it blow? You may have a defective fan that will keep blowing fuses.
