Spark plug choices
2004 CLK 500 Previous: 2001 CLK 430
Spark plug choices
It's about that time as I'm just over 180,000 km (about 110k miles).
Looking to change my plugs, I have found some options and wondering what you guys thinks what some of the benefits or real improvements of going with one over the other would be.
Also is there any reason to change the wires as well.
NGK standard plugs about 60 shipped from ebay. (rated 30k miles)
Bosch OEM equivalent plugs about 100 shipped from ebay.
NGK iridium IX plugs about 135 shipped from ebay.
I used Bosch OEM. I did some reading about the subject when it was time for me to change and saw no real reason to get anything other than oem.
Also check out autohausaz. They are having a sale on spark plugs and you might be able to get some cheaper over there.
I used Bosch ignition leads. I used NGK laser iridium's as I didn't want to touch them again for 80,000km and I *believed* they were the best spark plug- obviously this can be debated.
If the leads have not been changed ever then I would change them. I did it for piece of mind. I didn't notice any change in power, smoothness after changing either leads or plugs but it was running great beforehand. I just assumed they had never been touched.
Hi M-Rods,
There are a lot of choices for spark plugs. If your CLK is not running any power adders, I would recommend using the OEM spark plugs. That's what Mercedes engineered the car to run best with. Take a look at the Bosch 7422's, these are the Platinum OEM plugs. We could get a set to you for $82.88, shipped to your door.
Bosch Spark plugs # 7422
Hi M-Rods,
Just a quick question: what are power adders that you speak of?!
Hi M-Rods,
