burning smell in through vents
04 clk 320
Hey i recently purchased an 04 clk after my previous car drowned in a storm. I noticed i a burning oil.smell after driving for about 20 minutes...any ideas on what this could be. Thanks a lot
MBworld Guru
Check for oil leaks on the valve/head covers. Specifically, the passenger side. The seals tend to start leaking and oil drips onto the exhaust manifold. It's a fairly easy and cheap DIY repair. Just use OEM gaskets - some aftermarkets (like Victor Reinz) are too thin and will leak even worse.
W209(sold), W212, X204
MBworld Guru
Yes, this is a common issue on all M112 and M113 engines. I don't see that the part numbers were revised, so my guess is that they just end up leaking over time. Luckily it's an easy and cheap repair.
