star xentry/das
Old 10-15-2014, 02:30 AM
mylona78's Avatar
clk200 w209 2004 kompressor
star xentry/das
can i use das/xentry on my laptop without the sdconnect ???
Old 10-15-2014, 10:24 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
So you just want to use it to access WIS, and use DAS/Xentry in simulation mode? Sure, I do that all the time. I have a the 2011 version as a virtual drive using VMware player. I use my ole Dell D630 to connect to the hardwired RS232 multiplexer for actual work. To just "play" and use WIS, EPC, etc., I have a copy installed on my Lenovo Yoga notebook.
Old 05-25-2015, 05:34 PM
Chilli220's Avatar
C220 CDI W204 2008 model
Hi Rodney
Do you know where I can download the DAS Xentry 2011 from? I have been searching this for a while without much luck.
I bought the STAR C4 recently but comes with DAS Xentry 2014 unfortunately it does not have the W204 option to select.
Old 05-25-2015, 08:20 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I'm not sure why the 2014 version would not have the W204 - that makes no sense! The newer versions always are always backward-compatible with older models. As for getting a copy of the 2011 version, I'd check eBay - it's probably going to come on a handful of DVDs or a hard drive. It's a big program.
Old 05-26-2015, 10:02 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
You probably have a bad installation. If you have the C4 it should work without issues.
Check out *******.com for downloads. You have to pay to become a member of the site but it's cheap and you'll find everything you need there.
Old 05-28-2015, 12:26 PM
KoFidee's Avatar
W639 W205
yep very handy site when it comes to diagnostic stuff
worthy of the 10 bucks sign up
Quick Reply: star xentry/das
