Rear Driver Side Window Problems
Howdy all
i have an 04 CLK 320 and am having problems with the driver side rear window. It goes down fine but will not go up. I can hear the motor turning fine, which has me wondering if it is a regulator. They are $450 and i really do not want to spend the money. Any chance it is just off the track or something minor that is an easy fix?
MBworld Guru
One point of failure on the regulator is a plastic bushing that you may be able to replace. I haven't done this myself, but I have heard others mention doing this. You can get bushings from parts stores (usually for older Ford/GM cars) so you just need to find one that matches. if that's the issue.
BTW, I just posted the WIS docs here:
https://mbworld.org/forums/clk-class...rr-window.html
If yours is a coupe, here's the doc for paneling removal:
http://benzbits.com/w209/RemoveSidePanellingCoupe.pdf
Sometimes for some odd reason my windows would go down fine but when I want both front windows to go up at the same time, either the driver side stops halfway or the passenger side stops. Sometimes it even goes back down. This happens like once every few weeks/months.
MBworld Guru
