2004 CLK500 *ALL* Fluids Replacement
Old 12-08-2014, 08:48 PM
faran's Avatar
2004 CLK 500 with AMG Package, Not Convertible
Guys, I am consulting you for replacing *ALL* fluids on my 2004 CLK500, since finally I am getting to a point where I can actually do this stuff now:
1-Brake Fluid replacement with brake bleeder tool or pump/pump and bleed method. Is it appropriate and fine?
2-Power steering fluid, how can I do it?
3-Radiator coolant replacement, how can I do it?
4- Automatic transmission fluid, planning to drop the pan, replace the filter and add 4-5 quarts of Shell ATF. Any tips?
5-Engine oil(Mob-1) has been in the car for 1 year, but have less than 3,000 miles, should I replace it?
6-Air filter, how often they should be replaced and where can I get them cheap?
Any helpful video, thread or advice would be greatly appreciated.
Thanks in advance for the help
Old 12-09-2014, 01:06 AM
xsever's Avatar
2012 C300 4MATIC Sport
4- You also need a gasket and a filter and the rest is as you said.
5- You also need a filter here and oil should be changed every 13,000 miles or 1 year whichever comes first so yes go ahead and change it.
6- I bought air filters online before. www.rmeuropean.com or Amazon.
Old 12-09-2014, 02:54 AM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
1) Not 100% on this, it is my next job to replace the brake lines and fluid.
2) Not sure how you drain it (my hose burst). To bleed have the front end up on jack stands, pour new fluid into the reservoir, turn steering wheel from lock to lock to bleed the air and keep adding fluid.
3) I am doing this now, there is a drain on the bottom corner of the radiator. To get the fluid in the block you need to undo the drain plug near the back. I didn't do this. I changed the fluid via radiator only back to back 3 times with distilled water and I will do the final replacement with mercedes coolant in a few days. This gets 7.5/11.5L out each time. If you do it 4 times you get 98.6% of the old fluid out without having to even get a jack let along crawl under the car and risk having the block bolt not seal properly.
4) I did this recently, I imagine a lot of your questions might be answered in the thread I made. Order genuine pan gasket, drain bolt/washer, fluid, lock pin and its not a bad idea to replace the electrohydraulic bush if you are game for it.
5) I always wait for the mileage rather than time but that's just me. I wouldn't but it certainly won't hurt.
6) Genuine mercedes are not that expensive. Parts.com and a bunch of other sites have some of these items cheaper than the dealer.
Old 12-09-2014, 02:57 AM
tw2
tw2's Avatar
Brake fluid https://mbworld.org/forums/clk-class...ing-fluid.html
Transmission fluid https://mbworld.org/forums/clk-class...ion-flush.html
My power steering episode https://mbworld.org/forums/clk-class...ering-yay.html
Old 12-09-2014, 09:33 AM
faran's Avatar
Thanks tw2, appreciate it.
1- Yeah, I am going to use classic brake bleeding technique to replace the fluid. I have this brake fluid "81220142156 Brake Fluid; DOT 4 LV Low Viscosity; 1 Liter"
2- Can I just siphon off PS fluid and add new while moving steering wheel end to end? I have this fluid " CHF11S Power Steering Fluid; 11.S Synthetic; 1 Liter"
3- That's a really good tip and smart advice, just crack the drain bolt and wait for the coolant to drain? Not sure if my car has a drain bolt or no? Can you please share a pict of it? 4-5 gallons of distilled water should be enough, correct?
4-I have filter, gasket and fluid. Not planning to replace lock pin, screws and drain bolt/washer. Should I replace all whatever you did?
5-Going to replace oil and filter
6-Do I need to two air filters and are they easy to replace?
Old 12-09-2014, 10:39 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
1 - Any method of bleeding is fine. The pump the brake method works fine. Just get good brake fluid.
3 - Crack the drain plug let it drain. You can flush with water a few times if you want but if the coolant is not old/dirty I see no reason to complicate things.
4 - Make sure you have the correct transmission fluid. In order to do a flush you'll need more than the transmission can hold. Drop the pan, replace fileter and gasket. Add whatever fluid you lost.
To do a full flush: Disconnect the transmission cooler line at the radiator, start the car, let the transmission pump out 1-2L of fluid at a time, turn car off, add new fluid (whatever you removed). Repeat until fluid is clean/red.
5 - Replace the oil. It's not that expensive.
6 - Depends on the filter. Take a look at them. Are they dirty? Then replace.
7 - Differential fluid? That's also a fluid in the car
Old 12-09-2014, 11:00 AM
faran's Avatar
Thanks, since you suggested that, so how can I do it?
Old 12-09-2014, 12:14 PM
megacrazy's Avatar
I think there are vids on youtube. It's pretty straight forward. Open drain bolt and refill.
Old 12-09-2014, 12:16 PM
faran's Avatar
Thanks, what kind of differential oil and how much is needed for a drain/refill?
Old 12-09-2014, 06:41 PM
tw2
tw2's Avatar
Yes sounds like the right power steering fluid. It should also say pentosin on it.
There is a flat round plastic "tap" on the bottom of the radiator left side of the car. Turn it and coolant will come out a small pipe just above which points backwards. I slipped a small hose over it and directed it into a pan. You need to remove the plastic under cover to access it. If you have clean clear blue Mercedes coolant i would do 2 drain/fill cycles only which gets over 80% of it changed with minimal effort. Mine was green non-oem anti-freeze hence i am doing 4 drain/fills. This method also also has the advantage of mixing with the heater circuit coolant while you drive with the heater on in between changes. It's summer here so great time to have the heater blasting. You get 7.5 liters each time which is approximately the same in qts so 3-4 gallons and 3 liters of blue concentrate will suffice.
You have to break the lock pin to fill the transmission so i would get a new one. They are approx $1 same with the drain bolt and washer which are one use only. You can either to a full flush as outlined above which is best. Or you can just drain the fluid, replace filter and refill. This changes about 45% of the fluid. It is much easier and if you do it regularly you will have a healthy transmission. You will need to buy a dipstick to measure the fluid level.
Oil is approximately $150 here which is the only reason i wait longer to do oil changes. Mobil 1 is very cheap overseas so go for it. Air filters are easy to change.
Old 12-09-2014, 10:11 PM
mis3's Avatar
2004 CLK320
When my indie did my ATF pan flush, he would lossen the pan bolts bit by bit and let the ATF came out first then dropped the whole pan. I asked why and he replied he did not want to "disturb" the drain plug. He then cleaned the pan thoroughly and put it back with a new gasket.
I am still using the original pan and drain plug.
Old 12-09-2014, 10:15 PM
faran's Avatar
That makes perfect sense and I am going to follow exactly what he did, did you do a full drain or just dropped the pan?
TW2, can you please share a pict of the radiator drain bolt, please?
Old 12-09-2014, 10:19 PM
faran's Avatar
Did you replace differential fluid too? Do you have the part number for the locking pin?
Is full flush better than dropping the pan or it's an overkill?
Old 12-09-2014, 11:27 PM
mis3's Avatar
2004 CLK320
Just a pan flush.
Old 12-10-2014, 01:06 AM
tw2
tw2's Avatar
My car is back together so here is the terrible photo from WIS (the mercedes workshop manual if you are not familiar with it, $20 on ebay). Trust me you cannot miss it, nothing else looks like it. It is number 4, and number 3 is the small hose it comes out of. Of course it leaks all around the plug thing as well.
Sorry no part number for the locking pin but it is just a small red plastic clip and costs $1 or so. Just get it from the dealer.
A full flush involves taking the return hose off that goes back to the transmission and starting the car until fluid comes out, turn car off, fill up with more transmission fluid and repeat until all the old stuff has cycled out.. OR flushing with a fluid swap machine which does the same thing. These methods are better than just swapping the fluid in the pan since you are replacing all of it not just 40-50% of it.
I did a pan drop and only changed that fluid approx 3.6 liters in my case because it is extremely easy, doesn't require any particular skill or equipment and I rather do that every 20,000km than pay the $900 they want for the full flush at the dealer. Next time I will only change the fluid, I will not drop the pan and change the filter again. I possibly I will do this every 2nd or 3rd time instead.
This is just my opinion, you must do what you are comfortable with so please feel free to ignore it but- I see no reason not to take the drain bolt out of the transmission pan to drain it. It is not torqued in that tightly (20Nm), the replacement one is literally $2-3 from the dealer and unless you have a car lift and awesome skill I promise you will make a huge mess if you try and remove a full pan. Clean the area, it comes with a new washer anyway and it will definitely seal perfectly.
Old 12-10-2014, 08:55 AM
faran's Avatar
Thanks so much, let me put the car on jack stands in the coming week and will post here if I couldn't find it.
I am going to do a pan flush, better than nothing. Going to check with the dealer for locking pin and drain bolt/washer.
Thanks again for your help
Old 12-10-2014, 08:56 AM
faran's Avatar
Has anyone here ever done 'Differential Fluid'? If so, is it easily doable like engine oil, brakes etc...?
Old 12-10-2014, 10:10 AM
mis3's Avatar
2004 CLK320
I see no reason not to take the drain bolt out of the transmission pan to drain it. It is not torqued in that tightly (20Nm), the replacement one is literally $2-3 from the dealer and unless you have a car lift and awesome skill I promise you will make a huge mess if you try and remove a full pan..
This is the way my indie does his transmission service. He is actually a Sprint specialist and he services 722.6 transmision in a regular basis. Yes, he has a hoist to lift up the car with a canister to collect the ATF underneath. I don't think he is trying to save money on the bolt at all.
One thing I learned from him is you have to keep everything absolutely clean when working with the transmission. He cleans the pan inside out every time.
Old 12-10-2014, 01:51 PM
Kustom1911's Avatar
2004 Mercedes Benz CLK500, 2001 ML320, 2005 ML500
Changing the Diff Fluid is easy, the hardest part for most is filling it back up.
remove fill / check plug on left side of diff.
remove drain pug on bottom of diff, drain gear lube.
it takes 52oz. +- an oz. to fill in a normal open diff, limited slip ymmv.
I use Mobil 1 Synthetic Gear Lube 75w-90 LS (limited slip) as I have a lot of this around for my race cars. There are several friction modifiers additives you can add for longer life if you want. I have my wifes 04 CLK500 on a 100,000 mile change schedule for the diff.
Old 12-10-2014, 06:30 PM
mis3's Avatar
2004 CLK320
My CLK320 has almost 200k miles and I don't recall changing the diff. fluid.
How often should this be changed? What are the impacts if this is neglected, like in my case?
Old 12-10-2014, 08:02 PM
Kustom1911's Avatar
my wifes 04 CLK500 has 230,000+ miles, have changed the diff twice so far, so far no abnormal steel in gear oil.
if yours was never changed, i would do so asap. better to get the metal and gear oil out.
also to the original op, i have found that the best trans pan gasket is Woco, the supplier to mb, and i always use the mb filter, i get them @ rm.
i have flushed the trans 4 times so far, i have converted from using the pan bolts replacing them with studs and nuts.
Old 12-10-2014, 11:11 PM
tw2
tw2's Avatar
I am sure it works perfectly for him and there is definitely nothing wrong that method. +1 on the keeping clean, I used a gasket remover to get all the gunk off the sealing surface and spent 30 minutes cleaning the pan and magnet. They actually changed the shape of the drain bolt from the one on my car when I started.
Do you need a pump and hose? I have not done mine either. Another supposedly sealed for life component.
Old 12-11-2014, 09:10 AM
Kustom1911's Avatar
If i did not have my commercial air operated gear oil pump, i would use a suction gun(oil transfer gun), which looks like a full size grease gun with a 1/2" tube on the end.
Old 12-11-2014, 09:54 AM
Kustom1911's Avatar
tw2, any fluid in any vehicle has a designed purpose & life span which is not forever. only makes sense if you want to sell new cars, parts, and service.
whenever we purchase a vehicle, one of the 1st things i do is put it up on my lift, and make a maint schedule.
my favorite CLK misconceptions are:
filled for life fluids, lifetime vehicle wheel alignment, they cannot be aligned, they are hard on tires, they are hard to work on, as good as MB approved fluids.
if you hear any of these lines, be skeptical of the info you are getting.
we purchased the wifes 04 CLK500 used because she puts so many miles on. overall it is a very dependable car when properly maintained. the way she drives on a lowered CLK, she gets over 60,000 miles on a set of tires, and on 1 set she had 76,000 miles.
Old 12-11-2014, 11:14 AM
mis3's Avatar
2004 CLK320
I called MB delaership and I was told that the differential fluid is life-time. Here we go again, just like ATF.
Quick Reply: 2004 CLK500 *ALL* Fluids Replacement
