How is this part called?
i think the OP has lost that middle body part and posting an older pic.
BTW, if you dont mind, show a pic with it off!lol I always kind of thought the car would look better without it
Mine was damaged too a month ago when someone backed into me. The body shop person took care of it and replaced it so it's definitely a separate part you can buy however maybe not new but from a junkyard/used car lot.
Sorry I have no part number.
P.S. Make sure the temperature sensor gets reattached correctly. Mine was not and it cause erroneous readings.
2003 CLK320
Correct if I am wrong but if believe it's called front bumper center cover w/o AMG. You can buy it for around $200 new from Mercedes OEM part websites like parts.com
the part number is 20988500221693
https://www.parts.com/index.cfm?fuse...r-CENTER-COVER
MBworld Guru
Are you talking about the "protective strip" that covers that area of the bumper? I have searched EPC and cannot find them as separate parts for the W209. Ironically, I can find then for the W203, W211 and others. I know they are specific to the W209, but they are similar enough to the other models that one would think they would also be available for the W209.
2003 CLK320
MBworld Guru
I think I know why I can't find a part number for those bumper "rub strips". I removed the bumper on my CLK today (I'm having a local body shop repaint it as it's all chipped from rock when I worked in an industrial area). Anyhow, I was removing all the trim and I discovered that these rub strips, at least on my AMG Sport bumper, are just molded into the bumper itself and not a removable part as on the W203.
2003 CLK320
