Check Engine Light
Current: 2011 SL550 Previous: '07 CLK550 Cabriolet 1981 240D
Check Engine Light
I changed the air filters last week and evidently didn't seat the large cover (air cleaner housing) properly. I beleived this caused my check engine light to come on, based on reading the forums. I noticed my engine was shuttering a bit a stop idle. I seated the cover properly yesterday, the car is back to a smooth idle and my check engine light is still on. Will this go eventually go off on its own or do I somehow have to reset it? I do not own a device to check the engine codes. Is this the only way other than going into a shop to have them turn off the service engine light?
But to answer you other question, if it does not go out there is no other way than to go someplace that has the tool to turn it off or borrow one. They are handy to have and don't cost much.
Thanks. I will keep my eye on it for the next couple of days to see if it goes out on its own. I saw in some threads there is a device on Amazon that sells for around $20 that will show check engine codes, that attaches to a cell phone via Blue Tooth. May I assume this device will allow me to reset, if necessary?
2007 BMW 550i
This is the one I saw on Amazon and I think has been mentioned in some threads.
I do have a Sumsung Galaxy 5 phone and not an iPhone. I will go ahead and buy this one unless someone tells me there is something better or this one doesn't work. Thanks.
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
