KEYLESS GO DOESNT WORK
2004 Mercedes-Benz CLK 320
I bought a 04 CLK and am not sure if I have keyless go or not. I have the start button on the shift knob, but it doesn't work. Also, when I take the key out of the ignition, I keep getting a message that states "Please don't forget key".Also, I have 2 black squares on the door handle one is the IR and the other is like a button but nothing happens when I press the button or the back of the handle.
Also the car the remote doesnt unlock the car except if its veryyyy near to the reviever.
So does that mean that both this problems is cuz of the IR ? If not then what it is ?
p.s:The car only came with one key and this is my first merc which i bought from just a week.
Thank u in advance.
Thank u in advance.
2007 BMW 550i
The IR sensor on the door handle is used mostly for closing/opening the windows using the key (holding lock/unlock). Your CLK uses the a radio antenna located on the top of the rear windscreen, looks like somethings wrong with that. I have a feeling that affects your car reading your key when its in the car, but i cant help you out with more then that, no experience with keyless go.
1 Post
Mercedes-Benz CLK320 W209
Same exact issue
I had/have the same exact issue. The issue w/the secondary non keyless go key was indeed the battery within the key fob. Super easy to change, and the batteries are available at just about any Target, Walmart, etc. The battery (I believe) is a 2025 flat.
As for the "Don't forget your Key" alert when exiting the car, I'm in the same boat. I also have keyless go, but no smart key to utilize it / My car also came with one key and isn't the Keyless Go key fob.
I was thinking for awhile that the key has to be somewhere inside of the vehicle, in order for it to be alerting me every time I exit. I couldn't locate the key though and it does not start when the button is pressed..
2007 BMW 550i
Nomatter if the key is in the car or not u will always get that msg! No idea why mercedes designed the system that way.. If im not mistaken BMW give that same warning even when the key isnt in th car! Weird germans..
MBworld Guru
Pierce: I'm not sure what you mean by "secondary non keyless go key". As delivered, the vehicle came with two SmartKeys and both are KeylessGo transceivers. If you order a new/replacement key through a dealer, they know it is for a vehicle with KeylessGo and it will also be a a KeylessGo transceiver. If you have two SmartKeys and one works for KeylessGo and the other does not, then you have a bad key.
I believe batteries are the usual suspects with these keys. My key eats through them like crazy for some reason but in my case im suspecting something wrong with the key itself
1 Post
Amazing!
Rodney,
Thanks for your tip! I never fully inspected the possibility that the "basic" looking key fob was actually keyless go. I pressed and held the brake*, hit the start button, and she fired right up.
Thanks again!
Thanks again!
If I remember correctly, from 04 on, the keylessgo is built into the actual ignition key/remote. Before then (like on our 02 CL500), it was a separate credit card looking remote (so you'd actually have 4 keys with the car: 2 regular and 2 keylessgo).
2007 BMW 550i
That is weird. Since your car most definitely has keyless go because of the msg "dont forget key" i'm guessing your drivers door handle was replaced with a normal handle. I think most probably your problem is with your receiver in your rear windscreen, you should be looking into repairing that first because its probably related to reading how close your key is to the car.
Also did you try pressing on the brake then turning on the car using the button? And no your not supposed to insert a key anywhere, just press the brake and press the button.
If pressing down the brake then the button doesn't do anything, then we're back to seeing whats up with your radio receiver. Is your car's rear windscreen tinted? sometimes water can get into there from the tinting process and that will damage it.
2007 BMW 550i
well if it is the receiver in the rear windshield it was around 400$ last i checked, the stealership will tell you to replace the rear windscreen as well since they are connected, but that's not necessary 95% of the time. Could be a simple communication error though and there's no need to go changing parts. Find an independent shop with STAR, and knows how to use it, it should be easy to diagnose from there.
Received 1,467 Likes
The cheapest thing to do is to just change the batteries in the fob again. Those cheap knockoff batteries sometimes just don't have enough power. I think common problems on keyless go would be the wires being broken under the shifter if the button doesn't work. Also on the door handles, those buttons do wear out. Does the door open if you pull on the handle? There's a button under the handle that unlocks the door. Normally the handles go before the receiver, but the only way to really tell is to plug it into star diagnostic. You might also want to get another key because it's also possible that the key is bad, but you should call around to a few dealerships and see what their prices are, they all have to order them so it takes a few days to get another key. It's expensive though which is why you should always buy a car with two keys these days.
Star gets mentioned a lot in the forums, you can do a search for some of the older threads, but basically it's what the dealer uses to diagnose the car. Some people buy cheap knock offs, but even those aren't cheap, at least $350-$650 for a system, basically a laptop with cables and Mercedes' diagnostic software. $250 is a lot for diagnostic, but I guess that's middle east prices, in the US, the door handles are $175-$225 each online, but the dealers charge $300+.
The gearknob button is probably a broken wire, you can probably do a search and find some threads where people talk about opening up the shifter and finding the broken wire. You would have to order a spare key. Also what's the VIN of your car? If you run it through Mercedes's Epcnet, it should tell you if you have the keyless go feature.
MBworld Guru
Is this a USA model? I know the MY2005s sold in the USA all had KeylessGo integrated into the SmartKey.
