seatbelt presenter
clk 240 convertible
seatbelt presenter
Hi I have a 2003 CLK240 Convertible.
The passenger seatbelt presenter doesn't move when the door is opened.
I have verified the door switch is operating as it should so removed the trim, can someone identify the two connectors in the door.
Seatbelt runs freely and locks when pulled hard.
Steve
MBworld Guru
I assume the driver's side works properly? If not, it may be a soft top issue (the seatbelt presenters won't work when the soft top is not fully opened or fully closed).
Since you have a CLK240, you are not in the USA, and yourphoto appears to be the left side of the vehcile, so you are RHD, correct? Try pulling the fuse for the left "rear" door control unit for a few minutes to reset it. It's number 32 on the cabin panel (or #33 for the right).
