KMAC Rear Camber/Toe Kit
I bought and had installed the KMAC rear camber/toe kit about 2 weeks ago.
Assessment;
1. they are not cheap ($)
2. they are made very well and the engineering seems solid
- the installation shop (Butler) was impressed
3. the installer took 3+ hours to do the install and align
- they had to remove the arms to press out the old bushings (frozen)
- normally, I think the removal tool from KMAC would work
4. rear camber adjusted from -1.9 to -.9 (car is lowered)
- the specified range is -1.8 / -.8
5. the improved handlings (steering seems lighter) may be due to other alignment adjustments. The front total toe was very negative (-.19). I tested holding tight curves on a couple of my local favorites.... All ok.
6. it takes more of the gas petal to break the tires loose from a standstill now that more thread is in contact with road. Braking is also more solid.
7. it also looks better from the rear without the excess (track) negative camber.
I received the incorrect toe bushing set in the initial shipment but Kevin (KMAC) did a great job in correcting the problem and getting me the correct bushings for the toe arm.
Very pleased with the product so far. I'll try to remember to update here again when I take it back to the installer for a check after a few thousand miles of driving.
Assessment;
1 Post
W209, E46 M3 (dead), S54 swapped E46 Touring
great review, i have been looking at purchasing the front setup but just went with oem camber bolts to see if that will fix my issue with a $30 part expense. i am currently using the ghostrider rear camber kit but have sent an email to K-Mac and waiting to hear back from them.
If I were younger and had the time I could have saved $250-$300 on the install.
Just didn't want people thinking the kit itself is too pricey.... It is, IMO and pending on the results of the next 5K miles, a good value.
Excellent post. I have thought of getting these myself since I get new rear tires every 13,000 miles. But the price of the kit and install combined does make me have second thoughts. When my tires are toast, they are toast on the inside first, but it's not like they are nearly new on the outside edges. I figure I lose maybe 3,000 miles of use. It would take a while to pay for these at that rate. My car is not lowered though, so my negative camber is not that extreme.
Yeah! I was changing the rears at about 12K miles. I ran the last rears about 15K miles, but the tire safety cords (white) were visible on the inner 20% to 25% of the tires. There was probably 5-6K of usage on the middle to outer edge. As others have posted, with pro-rating you can effectively get the usage up to another 5-7K miles.
My biggest driver for installing them was getting better traction on acceleration for more of the life of the tire, and some concern with being able to slow or stop the car well from 80+ mph. Generally after about 4-5K miles on a set of rears I could create quite a scene at will with tire squeal and too often, chirps when the tranny shifts from 1st to 2nd.
Rear Camber Kits??
Is the only reason to get a rear camber kit because of lowering the car? I have a stock C:K500 Cab. with oversized tires all around on stock rims. I'm getting 30 to 35 K out of my tires. I'm only on my third set of tires. at 68K total miles 285 Rear 245 front
[QUOTE=Everythingsfast;6521667]Is the only reason to get a rear camber kit because of lowering the car? I have a stock C:K500 Cab. with oversized tires all around on stock rims. I'm getting 30 to 35 K out of my tires. I'm only on my third set of tires. at 68K total miles 285 Rear 245 front
Lowering the car increases the negative camber and I don't believe there is a stock adjustment for the rear camber, hence you're at or beyond the range limit and the inner 25% of the rear tire threads are gone at 12K miles. If you're getting 30K miles from the rear, I would not install a camber kit.
I don't know but the 500 may not have had the designed negative camber, as the 550 does. My original rear tires only lasted 15K miles.
The suspension is much more complex than thought, before doing some investigation leading to the KMAC rear camber/toe install.
