How many battery installed on CLK W209 ?
Looking to buy second hand CLK, and got some question here.
How many battery installed on CLK W209 ? I heard that in W211 there are two
batteries located in hood and trunk. I'm not sure CLK also has two same as
w211 or not
Thank you for your answer
w211 or not
2004 CLK 500 Previous: 2001 CLK 430
It's heavy, put a blanket on your fender just in case. You almost have to swing it in and down on a 45 degree angle. You will also need a long extension for your rachet to reach the tie down bolts.
MBworld Guru
And when removing the battery, lift the hood fully upright to the "service position". To do this, raise the hood, then press the red button on the hydraulic strut on the left side, and then raise it more.
